EFI and new cam selection - Chevelle Tech
  • 1 Post By RR24
post #1 of 7 (permalink) Old Dec 10th, 18, 10:13 PM Thread Starter
Wes
Question EFI and new cam selection
Engine is a 396 with 049 heads, going in with a new cam and plan on putting on a EFI setup next fall, would you use one of the EFI cams like the ones COMP cams or Lunati have or just go will a cam that has decent vacuum say 12" or above.
Thoughts?
Kopfjaeger likes this.
RR24 is offline
post #2 of 7 (permalink) Old Dec 11th, 18, 8:10 AM
I would cam the motor based on how you want to use the car.
Since it’s a 396, I’m guessing your looking at a throttle body efi like fitech or sniper. I know my fitech works with 7” of vacuum as that’s what my motor pulls. I believe the sniper system will too, but I don’t know for sure.
Your best bet would be to contact a cam grinder / company and see what they recommend for your combo and intended use.
mcollins6 is offline
post #3 of 7 (permalink) Old Dec 11th, 18, 12:16 PM
Re: EFI and new cam selection
as mcollins6 says, cam it to what you want the engine to do. I'd only recommend not going below 110 LSA, as EFI doesn't like overlap.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #4 of 7 (permalink) Old Dec 11th, 18, 12:47 PM
Vortec Pro put me on this Isky cam. Currently I have a Comp Thumpr cam with no vacuum which i've read TB FI doesn't like. My Fitec runs fine, but i have no comparison. So I'm throwing the Isky in this weekend and looking forward to having vacuum and, oh, power brakes..
396265/275 RR-265/275 HYDRAULIC ROLLER
Good mid-range power. Good vacuum & good idle. 3.23-3.70
axle ratio. 9.5-1.5:1 compr. Computer compatible with stage 1
chip. Stock converter. Up to 650 CFM Carb.
2000-6000 lift .530 .533 lash .000 advertised duration 265 275 @ .050 218 228 LSA 112
67 Chevelle 454, M21
Gen IV 454 (out of C30 ), 390 heads 1.88/2.19 valves by Vortecpro, with ISKY Hyd Roller cam (at 050 218 int./228 exh, lift 530 int./552 exh.), RPM performer intake, Fitech 600HP, Dougs headers, and M21, Gear Vendors OD, 3.73's, UMI Suspension, Viking coilovers.
mdelgado is offline
post #5 of 7 (permalink) Old Dec 11th, 18, 2:28 PM
I think I saw one of the holley techs say 7*on vaccum was the basement for sniper.
'67 Malibu,468 w/TH400
Project-
72LS3Z27 is offline
post #6 of 7 (permalink) Old Dec 11th, 18, 6:35 PM Thread Starter
Wes
That is about the size of cam that I have been looking at, the one I have now is EDL-7162. Edelbrock. RPM: 1500-6500. @.50" 240/246
Duration 300/306. Lift 560/573. LSA 112. ICL 110 and I really don't like it much.
RR24 is offline
post #7 of 7 (permalink) Old Dec 19th, 18, 9:14 AM
Thoughts?
What EFI? That would help knowing. With MPFI and a system like Holley Dominator/HP you can control injector end angle. So in my opinion, go with a wider LSA and then start spraying fuel after the EVC (exhaust valve closing). Gain some good driveability.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
This Thread is more than 523 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
