Making the EFI switch need a little info! - Chevelle Tech
  • 1 Post By ChevelleFan70
post #1 of 13 (permalink) Old Nov 27th, 18, 5:00 PM Thread Starter
Ron
Tired of jacking with this quick fuel carb and going with the Holley Sniper and Tanks Inc tank kit.
Going on a 540BB with a airgap intake with a 7004 trans and was wondering if my current TV bracket will work or if there is a different one I'm going to need. Want to make sure I get the geometry right for the linkage.
ram396 is offline
post #2 of 13 (permalink) Old Nov 28th, 18, 1:49 PM
Re: Making the EFI switch need a little info!
If you're using the Holley 20-95 bracket -- no, it won't work with the Sniper. I tried.
I ended up using this one, https://www.summitracing.com/parts/fst-304147
-Dave
'70 Chevelle ZZ383/700r4/3.73, [email protected] -- MS3X efi / Hotchkis A-arms & Springs / B-body 12" brakes / 1.25" F-body swaybar / UMI rears & swaybar / JGC PwrStrUpg
ChevelleFan70 is offline
post #3 of 13 (permalink) Old Nov 29th, 18, 8:08 AM
Same bracket I am using.
JimP
vjp38 is offline
post #4 of 13 (permalink) Old Nov 29th, 18, 1:57 PM Thread Starter
Ron
Thanks for the info! Thinking about the Eldebrock Pro flow 4 also so I'm assuming it will work on the MPFI system too?
ram396 is offline
post #5 of 13 (permalink) Old Nov 29th, 18, 2:14 PM
No idea.. you're going to have to test fit it and let us know!
I have a single-plane multi-port EFI intake that I wanted to use, but the different TV cable brackets I tried interfered with the fuel rails. But I never tried that specific bracket on that intake. With that said, I'd guess Edelbrock has some sort of throttle/TV cable bracket solution because they generally have well-designed stuff.
-Dave
post #6 of 13 (permalink) Old Nov 29th, 18, 4:27 PM
I popped on the lokar bracket,little pricey I thought,but it worked great.I also use the lokar cable.
https://www.summitracing.com/parts/lok-tcb40hs
'67 Malibu,468 w/TH400
Project-
72LS3Z27 is offline
post #7 of 13 (permalink) Old Nov 29th, 18, 4:41 PM
The FAST bracket I posted is only a few dollars cheaper than the Lokar ($62 vs $70), so both are are a little pricey. But based on the pic, I don't think the Lokar will work with a stock-type TV cable that requires a square hole.
-Dave
72LS3Z27 likes this.
post #8 of 13 (permalink) Old Nov 30th, 18, 2:23 PM Thread Starter
Ron
You would think they would have some kind of info in the installation manual for different trans setups.
ram396 is offline
post #9 of 13 (permalink) Old Dec 5th, 18, 3:46 PM
-Dave
I believe it comes with the bracket. I want to say my pro-flo 3 did(I have the XT manifold).
I like the system, so far it has been super reliable and not really needed anything other than for me to set idle.
tacomatrd is offline
post #10 of 13 (permalink) Old Dec 6th, 18, 2:27 PM
Kevin
BTO makes a bracket that works for a multitude of different carbs/TB's. I used it when I had a carb then TB EFI and it was flawless and easy to set.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #11 of 13 (permalink) Old Dec 12th, 18, 1:55 PM Thread Starter
Ron
Originally Posted by chevy67 View Post
bto makes a bracket that works for a multitude of different carbs/tb's. I used it when i had a carb then tb efi and it was flawless and easy to set.
bto?
ram396 is offline
post #12 of 13 (permalink) Old Dec 12th, 18, 2:33 PM
bto?
Bow Tie Overdrives, https://bowtieoverdrives.com
post #13 of 13 (permalink) Old Dec 12th, 18, 3:58 PM Thread Starter
Ron
ram396 is offline
This Thread is more than 582 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
