Chevelle Tech - View Single Post - Installing extra "ign" terminals?
post #13 of (permalink) Old May 8th, 16, 8:09 PM Thread Starter
Olle
Re: Installing extra "ign" terminals?
Originally Posted by oldcutlass View Post
What all are you going you hook up? What is the total load if you add all the items up? Answer these questions and that will tell you what size wire you need.
Use this chart:
http://www.sunforceproducts.com/Supp...ctionTable.pdf
I don't know exactly, most of the terminals will be "just in case". Right now I have ignition, light warning and tach, and will need to hook up electric choke and stereo later. I'm thinking about installing two rear window fans as well, so in short: I want a fairly good amount of spare terminals for future accessories. I'll probably figure it for 15 amp per fuse and go from there.
1969 Malibu in progress
Olle is offline
