Chevelle Tech - View Single Post - Installing extra "ign" terminals?
post #10 of (permalink) Old May 7th, 16, 10:10 AM
oldcutlass
Re: Installing extra "ign" terminals?
You can create a bus by hooking all the terminals together on one side of the fuse block. I would use a minimum of a 10ga wire soldered to each terminal. Then use a 30a relay to power it up in the key on position and a direct feed from the battery to the fuse block. Putting a fuse on the feed wire is optional if the fuse block remains under the hood.
oldcutlass is online now
