Chevelle Tech - View Single Post - Electrical problem ..please help!!!
post #2 of (permalink) Old Apr 21st, 16, 10:24 PM
Jim Streib
Re: Electrical problem ..please help!!!
Chances are you have the small wires backwards on the starter solenoid.
Disconnect the battery, remove the small wires on the small studs of the starter solenoid, then position them so they don't touch anything, then reconnect the battery and see which one shows power only when the key is in the crank position and this would go to the "S" terminal small stud on the starter solenoid and then the other goes to the "I" terminals small stud on the starter solenoid.
You can use a test light for checking things or a volt meter.
Jim Streib is offline
