Chevelle Tech - View Single Post - Where to find sheathing?
post #3 of (permalink) Old Dec 31st, 15, 6:25 PM
Coppertop
Re: Where to find sheathing?
If you mean wire harness tape, then there are 2 types typically found in the trunk, the first being the typical non-adhesive wrap found all over the vehicle the wiring;
http://r.ebay.com/U8Kw0O
I'm sure you can find it cheaper if you look, this is for your reference.
And the other type being similar to "gaffers tape" which has a gritty feel to it as it is a tougher adhesive backed tape that was used in areas where the factory was concerned about damage from chaffing--like rear side marker lamp feeds on some cars where a suitcase or tool might try to snag them.
http://r.ebay.com/SkWfJd
Coppertop is offline
