Chevelle Tech - View Single Post - 65 Chevelle Wiper motor?
post #9 of (permalink) Old Nov 6th, 15, 11:40 AM
65chevelle300post
Rob
Re: 65 Chevelle Wiper motor?
Sounds like maybe you have a 67 motor like the two speed one on my friend's 67 Malibu Rob???
It's all original so I don't see how that can be.
It looks very similar to the Op's but the outlets on the pump come off at a 90 degree angle rather than straight down and it has another electrical connection along the left side of the motor. The switch is also a two speed switch and everything still works perfectly.
OPG sells both the single speed motor and the two speed motor for the 65 but doesn't appear to show one like Rich is using although I have seen those on other 65's. https://www.opgi.com/chevelle/1965/w.../wiper-motors/
My build thread>
65chevelle300post is offline
