Chevelle Tech - View Single Post - 65 Chevelle Wiper motor?
post #5 of (permalink) Old Nov 6th, 15, 11:14 AM
Rich-L79
Rich
Re: 65 Chevelle Wiper motor?
What you have there is a one-speed motor. The two-speed motors look completely different. You CANNOT swap a one-speed for a two-speed without also swapping the transmission arms in the cowl as they are specific to the motor used. Also, the two-speed motor uses an offset mounting plate (thus the need for a different transmission assembly) and of course a different switch on the dash. Make sure you have a one-speed switch. It should have only and ON and OFF setting while the two-speed switch has three settings, ON, LOW, HIGH. The two-speed also requires an additional wiring harness.
BUT, what you have is a one-speed so just buy a one-speed motors and remove and replace and you should be good to go.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
