DIY 496 Kit.... - Chevelle Tech
Straub Technologies
post #1 of 9 (permalink) Old Jun 1st, 11, 11:45 AM Thread Starter
DIY 496 Kit....
I've got in process a 496 DIY Engine Kit. You get:
OEM 454 Block
Bored and honed with plates to 4.310" Bore
ARP Main studs and line honed
Surface Decked and all holes chased with tap
Cam bearings and Brass Freeze Plugs installed
Rotating Kit
Scat 4340 4.250 Stroke Crankshaft
Eagle H Beam Rods
Probe 18cc Dome Pistons
Clevite H Bearings
Hastings File Fit Rings
Balanced to .01gms on each end
GM Damper
B&B Damper Bolt
Top Half
Complete Patriot Aluminum 320cc Heads
Straub Custom Solid Roller
GS Pressure Fed Solid Roller lifters
Smith Brothers 1 piece Pushrods
Tru Roller timing Set
Straub Cam Lock and Roller Button Kit
ARP Head Bolts
Scorpion Rocker Arms
Victor Jr
AED 950 Carb
Assembly items
Felpro Gasket set
B&B BBC Oil Pan for Chevelle Camaro
Melling Oil Pump
This combination will make 650HP/650#/ft of torque when assembled. This will come in kit form and you assemble it.
$6999.99 shipped to a terminal near you.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #2 of 9 (permalink) Old Jun 1st, 11, 2:31 PM
"Wild Bill"
Re: DIY 496 Kit....
Wow...KILLER deal Chris!!
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #3 of 9 (permalink) Old Jun 1st, 11, 2:39 PM
Re: DIY 496 Kit....
ahhhh...... If only I hadn't just had the car painted. I would consider tucking this away in the basement for a winter project. I need to sign off before I start trying to justify the expense.
cu. in. "cruiser"
Assembled & Tuned by
Dallas, GA
fleming23 is offline
post #4 of 9 (permalink) Old Jun 1st, 11, 2:42 PM
Re: DIY 496 Kit....
Geeze smokin deal!
Mike Smith
72 Chevelle, LS 6.0 LQ9 4l80e
smitty454 is offline
post #5 of 9 (permalink) Old Jun 1st, 11, 3:13 PM
Matt
Re: DIY 496 Kit....
Ouch, too bad I didn't know about this about a month ago
Definitely a killer deal my friend.
402 BBC - TH400
71Avido is offline
post #6 of 9 (permalink) Old Jun 1st, 11, 8:32 PM Thread Starter
Re: DIY 496 Kit....
Block is in process, I will take a deposit and hold for 60 days for balance. Deposit would be $2000 to hold.
Chris Straub
cstraub is offline
post #7 of 9 (permalink) Old Jun 7th, 11, 12:42 AM
Re: DIY 496 Kit....
What's the compression Chris?
1970 Chevelle, 400, UD Harold solid, 5.565 rod, standard bore, vortec heads, Jerico DR4, best ET 11.85, 113 MPH
1961 Buick Lesabre convertible, bone stock cruiser
ChevJerico is offline
post #8 of 9 (permalink) Old Jun 7th, 11, 11:28 AM Thread Starter
Re: DIY 496 Kit....
It is 10 to 1 with the Patriots.
Chris Straub
cstraub is offline
post #9 of 9 (permalink) Old Jun 24th, 11, 11:46 AM Thread Starter
Re: DIY 496 Kit....
I will sell as a short block:
OEM 454 Block
Rotating Kit
Eagle H Beam Rods
Clevite H Bearings
GM Damper
B&B Damper Bolt
B&B Oil Pan and pickup
Melling Pump
$3955 shipped to the lower 48 to a truck terminal near you.
Chris Straub
cstraub is offline
This Thread is more than 3266 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
