NEW LS Rocker Arms with Limited Lifetime Warranty... - Chevelle Tech
Straub Technologies
post #1 of 1 (permalink) Old Mar 28th, 19, 11:42 AM Thread Starter
Straub Tech introduces our new Bushing LS Rocker Arm sets. These come with a limited lifetime warranty against body breakage. As long as they are used with a lobe lift of .375" or less the rocker body is covered for life.
We use an investment cast body that is shot-peened then is REM finished. Each rocker is assembled using our proven bushing trunnion kit. The bushing provides a great load area when used with modern day lobe profiles and valve spring combinations. The bushing also insures in case of catastrophic failure that you won't have needle bearings loose in your engine that can find their way to the oil pump.
Rocker kits for LS1 and LS3 are available right now. Kits come complete with Grade 12.9 bolts. Proudly made in the USA
Internet MAP $399 a set shipped to the door
Chris Straub
Mfg Performance Parts
cstraub is offline
This Thread is more than 473 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
GMPP Roller Rocker Arms 67 velle Performance 12 Feb 23rd, 13 6:31 PM
cam and rocker arms 86stepside Performance 2 Jan 5th, 13 3:03 PM
rocker arms 86stepside Engine 1 Jan 5th, 13 8:05 AM
Shavings from Rocker Arms 1967 chevelle Engine 9 Oct 1st, 12 9:39 PM
