Camshaft for Twin turbos BBC - Chevelle Tech
Straub Technologies
  • 1 Post By gnicholson
post #1 of 8 (permalink) Old Mar 5th, 18, 7:50 PM Thread Starter
Javier
Hi Sir I got a BBC 496 with 10:5cr Ultrade Harold Billet SR custom build a cam with cast distributor gear for this motor it ran 11.4e/t and it is very streeteble with a 3500 converter .Can I run two small turbos with this compression using Straub billet custom cam ? Harolds cam from Custom Camshaft
110 LSA
max lift in/ex .675
288 /296 (.020)
Please need advice if I can still run two small turbos with this BBC 10:5 CR with one of your custom build camshafts ,please quote me a billet can with the cast distributor gear ,Block is a Mark IV old GM Tall deck block,Do I need to buy new pistons to lower CR ? or a good cam will help me keep the 10.5cr combo?
The car is a 4100Lbs El Camino , You can verify my old post there with anUDHarold my RIP friend desing one camshaft for my motor ,Thanks Harolds cam from Custom Camshaft
110 LSA
max lift in/ex .3970
288 /296 (.020)
71 GMC SPRINT
new 496, still tuning
11.44
1.56 60ft
116.8 mph
all steel car
HPseeker is offline
post #2 of 8 (permalink) Old Mar 5th, 18, 8:44 PM
Gary
Re: Camshaft for Twin turbos BBC
Way to tight lsa you need around 116 or more. Also unless youre running race fuel thats to much compression. You really need to consult a turbo expert. Jones or straub may be able to suggest a cam
gnicholson is offline
post #3 of 8 (permalink) Old Mar 5th, 18, 9:57 PM
Allen
Maybe if you go e85 and keep the boost in check???
May want to consider piston material and where your ring gaps are, general thought process is that you need a wider gap with boost or nitrous. Just a thought.
Blown1932 is offline
post #4 of 8 (permalink) Old Mar 5th, 18, 10:03 PM Thread Starter
Javier
Yes I contacted Straub Technologies for a quote ,they respinde fast and send me the invoice quote I ask ,but I just want to know if with low boost 8 to 10psi and 10:5 cr wont kill my motor
71 GMC SPRINT
11.44
1.56 60ft
116.8 mph
all steel car
HPseeker is offline
post #5 of 8 (permalink) Old Mar 5th, 18, 10:17 PM Thread Starter
Javier
we havent talk about cam numbers yet,they said just limit boost on pump gas nomproblem with race fuel, my brother want me to build a new LS motor wrh twins and leave the old rock untouched ,this turbo idea is confusing
71 GMC SPRINT
11.44
1.56 60ft
116.8 mph
all steel car
HPseeker is offline
post #6 of 8 (permalink) Old Mar 5th, 18, 10:40 PM
Gary
You could probably do it with water meth injection. I would talk to a turbo expert
Steve R likes this.
post #7 of 8 (permalink) Old Mar 5th, 18, 11:20 PM
Vince
hi Javier
welcome to the site;
you can find alot of good info on turbos at this site:
https://www.theturboforums.com/
VinceS427bb is online now
post #8 of 8 (permalink) Old Mar 5th, 18, 11:53 PM
T_R
You need to change the cam. You could get away with 10.5 to 1 on race fuel or E85. But that's easy enough. The problem is turbos don't really exist for what you want to do. You can't put small turbos on a 500 inch motor for a little more power, it will just choke it and make no power. Properly sized turbos on an engine that large will make well over 1000 hp, so then you need to drivetrain, chassis and traction to go with it.
66 Chevelle crew cab 454 FiTech TKO 600 5 speed
T_R is offline
This Thread is more than 718 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
