Chevelle Tech - View Single Post - 66 P/T build
Thread: 66 P/T build
post #371 of (permalink) Old Sep 26th, 15, 2:24 PM Thread Starter
Mike McMasters
Re: 66 P/T build
Originally Posted by Dan65ss View Post
On another topic:
How are you routing your fuel lines over the rear cross member? Did you drill a hole and go through it or going over the top over by the stock placement? If so, is there enough room over there with 2 lines where they won't pinch when the body is on?
Thanks,
I ran them on the outside of the body mount then used stainless line clamps down the backside of the C notch, then over to the tank. I will get some better pictures for you and show you how I did it. When the body is on both lines have plenty of clearance around the mount.
The BBC thing was really hard for me to get past but I'm all good with it now
66 Chevelle Pro Touring build in progress
My 66 Chevelle build thread-
Mike McMasters is offline
