Tubing Rib Maker? - Chevelle Tech
Tools & Shops Shop Rat HQ
 4Likes
  • 2 Post By dyno jonn
  • 1 Post By buenymayor
  • 1 Post By JWagner
post #1 of 8 (permalink) Old May 25th, 20, 10:57 PM Thread Starter
Devin
Tubing Rib Maker?
I've seen a tool designed to be able to put a rib or a bulge in tubing so that that a hose is less likely to come off. What is it called and where do I get one?
Thanks,
Devin
Just an El Camino
Son's build:
My never-ending project:
64SS427 is offline
post #2 of 8 (permalink) Old May 25th, 20, 11:18 PM
Jon N.
Re: Tubing Rib Maker?
A double flaring tool can put a bulge at the end of a tube if you don't complete the second step.
BillyGman and Schurkey like this.
dyno jonn is online now
post #3 of 8 (permalink) Old May 26th, 20, 4:30 AM
You are looking for a bead roller. Here's one that will do 5/8" tube and larger: https://www.jegs.com/i/JEGS/555/8008...yABEgIBT_D_BwE
VinceS427bb likes this.
buenymayor is offline
post #4 of 8 (permalink) Old May 26th, 20, 6:20 AM
Banned
Bubble flare????
gumba1 is offline
post #5 of 8 (permalink) Old May 26th, 20, 2:04 PM
Cody
Blackhawk is offline
post #6 of 8 (permalink) Old May 26th, 20, 5:50 PM Thread Starter
Devin
Tube beading tool. Thanks guys. I knew it existed, had no idea what to call it to search for one.
Devin
Just an El Camino
Son's build:
64SS427 is offline
post #7 of 8 (permalink) Old May 26th, 20, 6:09 PM
There is a cheaper way.
Put a compression ferrule on the tubing IF you can slide the compression nut back off of the other end.
post #8 of 8 (permalink) Old May 29th, 20, 10:25 PM
I have used the same method as Dyno John. Just make an incomplete double flare. That type of feature is called a "hose bead". The flanged looking bead that is a distance from the end of the tube that locates the end of the hose is called a "stop bead". I got those bits of wisdom from a friend who had a business making all kinds of little bent tubing gizmos for the auto industry.
Schurkey likes this.
JWagner is offline
