spot welder - Chevelle Tech
Tools & Shops Shop Rat HQ
post #1 of 4 (permalink) Old Mar 22nd, 20, 10:00 PM Thread Starter
Terry
spot welder
Hi All, I recently purchased a 220 spot welder from HF. It came without a plug end, the wire is 12 or 14 ga. Does anyone have this same welder and if so, what plug end did you use? Thanks, Terry
68-13427 is online now
post #2 of 4 (permalink) Old Mar 23rd, 20, 10:59 AM
Re: spot welder
It'll depend on what you have. I matched the 220V twist lock plug to my 220V outlet. I use the same style plug/outlet for my compressor, welder, HF spot welder, and have a few extension cords made up with the same ends. I think they are NEMA L6-20P, and L6-20R male and female, and a matching receptacles. I prefer twist lock plugs for stuff like that you'll be moving around. BTW, I have the same HF spot welder, and it works really good.
This link for just for reference.
ZZ69chevelle is offline
post #3 of 4 (permalink) Old Today, 7:35 PM
Kev
Re: spot welder
This says 16A rating https://www.harborfreight.com/240v-s...der-61206.html
L620 means 240V 20A which is fine, but the OP needs to check the rating of the breaker feeding the circuit.
66sc is online now
post #4 of 4 (permalink) Old Today, 7:58 PM Thread Starter
Terry
Re: spot welder
Breaker is 20A, run from the same outlet i run my band saw from. Thanks Terry
