Stainless tubing bender? - Chevelle Tech
Tools & Shops Shop Rat HQ
 8Likes
post #1 of 19 (permalink) Old Oct 6th, 19, 8:45 PM Thread Starter
Does Harbor Freight sell a kit that can bend 1/2 stainless?
Need to make a new fuel line, like the look. This stuff has absolutely no give at all .
Nobody in these parts does this may as well go for it. Cheap if I make a mistake.
cuisinartvette is offline
post #2 of 19 (permalink) Old Oct 18th, 19, 12:47 PM
You will need a industrial style bender, it will only be able to bend the 1 diameter. With that said they do make a kit so that you can buy all 3 (1/4, 3/8, & 1/2) but it will be over 600-700. I would buy the one you need.
I bend all my stuff and stainless now and have never looked back.
Steve R likes this.
1968 Beaumont
540 BBC + 15psi Boost via Single Garrett GTX
Stock looking, and fairly stock sounding
HP and ET not determined yet!
Boosted Beaumont Build:
GoFast Beaumont is offline
post #3 of 19 (permalink) Old Oct 18th, 19, 12:55 PM
Bruce
Re: Stainless tubing bender?
Stainless is nice, but not so much for the casual do-it-yourselfer like me. I'm able to bend the regular stuff with my tools, but not stainless.
I but pre-bent stainless or bend the standard stuff.
Our You Tube Vids:
NickeyChevelle is offline
post #4 of 19 (permalink) Old Oct 18th, 19, 1:14 PM
IMO, you'd better off if you call one of the vendors that sells new lines & have them custom bend you what you need. By the time you invest in the tool & the tubing, then add the frustration of trying to bend it yourself, you'll be way ahead just buying it pre bent.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #5 of 19 (permalink) Old Oct 23rd, 19, 6:03 AM
I learned this the hard way as well, when i swapped my TH350 for a 2004r. had to reverse the lines on the trans, and holy crap, even with the aid of a decent tubing bender, that stuff was murder to massage them just enough to get them switched over. whoever put those lines in, was not a diy-er.
70montee is online now
post #6 of 19 (permalink) Old Oct 28th, 19, 6:12 PM
Art
Art
Working in the oil fields in west Texas I bent way more 3/8 stainless than I ever wanted to. I can tell you that it's not easy and a good bender is a must. I used a Swagelok bender, it was OK and a little pricey. I've never tried to bend 1/2" tubing but I think it would probably be near impossible to bend by hand.
Art is offline
post #7 of 19 (permalink) Old Oct 28th, 19, 7:12 PM
I haven't had much luck bending stainless, but it does look cool. Sorry, this post won't help you find a bender.
But - what I've moved to now is copper-nickel lines. They can polish up quite nicely (not super shiny like stainless but I think it has its own cool look) with some steel wool and are super easy to work with, and getting them to seal is a breeze.
hydro462 likes this.
lucifershammer is online now
post #8 of 19 (permalink) Old Oct 29th, 19, 8:56 AM
I think using stainless on parts like these is a waste.. I use the regular tubing that bends real nice and looks great...
hydro462 is offline
post #9 of 19 (permalink) Old Oct 31st, 19, 3:36 PM
I looked at this thread and had a great brain wave: Anneal the tubing in the region to be bent. So, I looked up what it takes to anneal it. Way high temperatures for hours. No way could that work for DIY projects. I see that Earl's has annealed tubing at Jeg's , but only in short lengths. So,,, the question becomes one of finding pre-annealed stainless in the size and length you need. I am no help on this, however.
OK, I have returned. It turns out that annealed tubing is a real thing. Here is a chart showing weight per foot of popular sizes. It looks like the length is 20 feet. I did a search on "annealed stainless steel tubing " and on "annealed 1/2 stainless steel tubing". Your luck may be better than mine.
http://www.alascop.com/pdf/ss/annealed_tubing.pdf
Jeff65SS likes this.
JWagner is offline
post #10 of 19 (permalink) Old Jan 1st, 20, 11:31 PM
J
Are you able to flare the ends of the 1/2” stainless tubing? If you must use 1/2” SS, you may find it much easier to accomplish “bends” by using the appropriately sized fittings (90/45 deg, etc) instead of trying to bend the straight sticks. It creates more potential leak points, but much easier than trying to man handle it without an expensive bender.
NorCal-SS is offline
post #11 of 19 (permalink) Old Jan 2nd, 20, 7:25 AM
HI
Try copper nickle or CoNk . able to be used for brakes and fuel . 1/2 is a little more uncommon .
Stainless to hard to work
Original factory lines had a ""Terne Coating "" Lead based with a small amount of zinc
Bundy tube or the brake line sold today is Zinc coated /dipped for a very short time . It has very LOW corrosion resistance
swampy 6x6 is offline
post #12 of 19 (permalink) Old Jan 2nd, 20, 7:50 AM
The Swagelok Tube Bender makes it look pretty easy:
NickeyChevelle likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is online now
post #13 of 19 (permalink) Old Jan 2nd, 20, 11:19 AM
Eddie
I ordered my 1/2" stainless fuel line from Right Stuff Detailing.
Bending 3/8" line was really hard, I'm assuming 1/2" stainless would be damn near impossible to bend with a handheld tube bender.
Eddie K is offline
post #14 of 19 (permalink) Old Jan 2nd, 20, 5:52 PM
FWIW, I did stainless brake lines with the elcheapo plier type tool from Harbor Fright where you just hold it then pull the tubing with your hand to make the bend. Nothing to it, easy-peezy.
Here's another video with a Swagelok type bender. In this one, they state that they're bending stainless. 3/8" looks easy, 1/2" can't be more than a little bit harder.
How may I help you?
1999 Trans Am-500hp
post #15 of 19 (permalink) Old Jan 2nd, 20, 7:08 PM
The Parker Hannifin version is part number 8-2829
https://www.ebay.com/itm/USED-PARKER...wAAOSw4DVeBihz
68 Chevelle [email protected] on Dunlop GT Qualifiers, through mufflers.
68 Chevelle Convertible-454, 12" manual disc brake conversion, B-Body Knuckles, rotors modified to hubs for the Vette rotors, HD Suburban 3-5/32" piston calipers, 75 vette master, DOT5, (stops like my 9C1 4-wheel disc Caprice)
bigdog454 is offline
