Compressor "rebuild"? - Chevelle Tech
Tools & Shops Shop Rat HQ
  • 1 Post By Schurkey
post #1 of 3 (permalink) Old May 7th, 19, 4:37 AM Thread Starter
I have an older Craftsman compressor (DeVilbliss). Seems to work well, but I noticed its starting to "seep" oil externally. It looks like maybe the base gasket needs replacing, which doesn't look too difficult to handle.
I wiped it down, and after 30 minutes of run time, the tank and motor base have an oily film... Not enough to "drip", but I imagine it will only get worse...
But since this compressor is about 30+ years old, I wonder if I should consider replacing the flapper/reed valves (and associated gaskets), just because. I'd estimate the compressor has under 100 hours on it, just a "home" compressor that I have painted a few cars, ran a DA sander and more recently spent about an hour blasting some rust.
I am looking to do some more blasting and painting.
Its a 30 gallon, portable, horizontal tank, 5 HP, 240Volt, 125 psi max pressure, 12 scfm @ 40psi and 10.0 @ 90 psi (8.3 @100)... I really like it because I can store it under my workbench when not in use. I placed the electrical outlet outside so I roll the compressor out when I need to use it, but its still convenient for me.
So should I just replace the valves (and head gaskets) while I have it apart? or since it ain't broke, just replace the lower base gasket?
Only about $33 for a gasket kit ($15+) and valve kit ($17+) I figure I'd but the valves anyway, just to have them around (a lot of parts have been discontinued).
Thanks...
TC #1366
Sold
Sold
1966_L78 is offline
post #2 of 3 (permalink) Old May 15th, 19, 8:02 PM
Re: Compressor "rebuild"?
I don't expect the valves are needing replacement with only 100 hours. Buy 'em...store 'em for "later".
Buy two sets of gaskets if you think they're gonna be discontinued.
OLDANDBROKE likes this.
Schurkey is offline
post #3 of 3 (permalink) Old May 16th, 19, 7:51 PM Thread Starter
Yeah,
a lot of the gaskets (full sets) and other parts have been discontinued... And some websites like Sears Parts, etc show a lot of parts not available. With some research, it looks like Devillbiss made this, and they carry some of the replacement parts...
TC #1366
Sold
Sold
1966_L78 is offline
