Chevelle Tech - View Single Post - Two batterys
Thread: Two batterys
post #5 of (permalink) Old Jul 16th, 05, 12:33 AM
undee70ss
Greg
Re: Two battery's
Originally Posted by driver
To run two batt's do you need a different type of alt?
Normally no, but only a 50 amp alternator would be to small if you had very many accessories running too. Also alternators are rated by their max output, they put out much less at idle and slower speeds.
Do you need to change some things? How does it work?
Depends on how its wired and what you want to do, run both at the same time, run one and just charged the other, keeping it as a spare.
Been having some problems with car stops running and when i try to restart the batt is dead.I run a small alt that only puts out 50 amps and was wondering if that is to small? BILL
Is this for the Nova in your sig? Street/Strip or drag only??? How many accessories do you have. First make sure the alternator even working, check the voltage across the battery with the car running at a fast idle. You need 14-14.5 volts at the battery to be charging it. The reason the car stops running is you are most likely just running off the battery, when the voltage drops low enough, dead battery.
Greg U
MY 70SS
undee70ss is offline
