Boosted Beaumont Build - Page 7 - Chevelle Tech
Beaumonts & Canadian Built
 56Likes
post #91 of 143 (permalink) Old Nov 16th, 19, 4:17 AM
Re: Boosted Beaumont Build
Originally Posted by GoFast Beaumont View Post
Nothing major in the last bit, waiting for parts and went to the Machiniest. Got the heater core seal kit in, lots of wiring to build a new secondary system, and a glove box!
Completed a rebuild on the front shocks as well, these QA1s are looking pretty well used after the last 10yrs. Should be able to get a couple more and then time for replacement.
Got some GM zz572/620 hydraulic roller lifters in, will do a full compare against a set of hydraulic roller Morels.
Machiniest gave me some bad news... no torque plate for 4.500 bores. Says its not common for him so... may have to build him one or take that part of the work to someone else.
Debating if I should splurge on a new wilwood front 6 piston brake kit for the car, any thoughts?
Are you changing over to 17-18" wheels? If you plan to stay 15's, the brake kits out there really don't offer any better performance than stock. You can lose a few lbs though.
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #92 of 143 (permalink) Old Nov 17th, 19, 6:39 PM Thread Starter
Completed a rebuild on the front shocks as well, these QA1’s are looking pretty well used after the last 10yrs. Should be able to get a couple more and then time for replacement.
Machiniest gave me some bad news... no torque plate for 4.500” bores. Says it’s not common for him so... may have to build him one or take that part of the work to someone else.
Keep the 15” wheels, Still really like the look. Yea ditch about 10-15lbs. Hopefully I gain something with there 12.20” rotor and 6 piston kit. Was hoping to up the ante this a lot with the rebuild.
1968 Beaumont
540 BBC + 15psi Boost via Single Garrett GTX
Stock looking, and fairly stock sounding
HP and ET not determined yet!
GoFast Beaumont is offline
post #93 of 143 (permalink) Old Nov 17th, 19, 8:49 PM
Keep the 15 wheels, Still really like the look. Yea ditch about 10-15lbs. Hopefully I gain something with there 12.20 rotor and 6 piston kit. Was hoping to up the ante this a lot with the rebuild.
If you are keeping the Nascar style 15s, then a 12.19 rotor will likely fit. 6 pistons will gain you nothing in stopping power, only the leverage of the larger rotor. I dropped 8.4 lbs going to aluminum calipers. I have 11.75x1.25 rotors which are a little bit heavier than stock though.
Youtube Channel.
Instagram:
Twitter:
post #94 of 143 (permalink) Old Nov 17th, 19, 9:22 PM
Beth
What about this ? If you torque a head bolt in each head bolt hole to full torque, it should distort the cylinder the same as a torque plate.
You need to make sure the bolts penetrate the same depth as normal.
nashville beth is offline
post #95 of 143 (permalink) Old Nov 18th, 19, 11:01 PM Thread Starter
Morel VS GM 572/620 lifter
GM p/n is 17120060.... OR HL 121
From my gatherings this is GM heavy duty lifter, mayby someone can correct me on that. It is used on OE 454/496 GM truck applications as well all mercruiser stuff for boats. These maintain stock oil flow to valve train, it is my understanding the 502 version allow more oil to the top end. This would make sense for high rpm heavy duty applications.
There are many similarities between the too. Plunger travel basically the same, GM slightly more by 0.040. Morels at .120 total. Check ball valve slightly larger on morels with the hole which the ball seats is larger. This usually means a higher bleed down rate typically with the additional surface area. The plunger spring on the morels is softer by a lot. Morel is a 2 piece design where GM is a 1 piece. There would be more movement of the parts in Morel bodies. Axles are held in by clips vs pressed like GM. The pushrod piling system is drastically different between the 2. Morel are relying on oil squiring by the body and upper plunger into a relief hole which supplies the pushrod with oil. I am not sure if this is a means of control for oil or not. The GM ones use a disk which site under a rounded rounder head plunger, I would venture to say these really let oil get up top. Morel oiling hole online with roller, GM one is perpendicular to the wheel.
Keep in mind my morels are used but the GM ones you can’t even push the plunger in as it compresses the air in the body. The Morel plunger just collapse’s to the bottom.
Honestly I like the GM ones, id Recommend them. I paid $37US/ea. For the rebuild I will only be replacing 8, I have 12 good morels which will be broken down, cleaned, and reused.
I am thinking they should perform fine given I don’t expect to shift this new combo past 5500rpm. Valve springs will be 155-160 seat pressure, 428lbs/in rate. GM 572/620 crate motor runs 197 seat pressure.
1968 Beaumont
post #96 of 143 (permalink) Old Nov 18th, 19, 11:04 PM Thread Starter
Morel hyd lifters
ID:	608616   Click image for larger version
ID:	608618   Click image for larger version
ID:	608620   Click image for larger version
ID:	608624   Click image for larger version
1968 Beaumont
post #97 of 143 (permalink) Old Nov 18th, 19, 11:05 PM Thread Starter
GM 572/620 lifter
ID:	608628   Click image for larger version
ID:	608630   Click image for larger version
ID:	608632   Click image for larger version
1968 Beaumont
post #98 of 143 (permalink) Old Nov 19th, 19, 12:15 AM Thread Starter
the machinist mentioned this as a alternative but said we should really use a torque plate.
As a added benefit of purchasing/fabricating one is that it could be used to set the ring gaps. Some say they see no change while others note almost 9 thou close up on the rings.
1968 Beaumont
post #99 of 143 (permalink) Old Nov 20th, 19, 7:17 PM Thread Starter
well I signed up for the 2020 Summit Racing Midwest drag event. Should be a awesome time as usual, this even is the same as drag week or race week. I will need to get this thing put back together and tested before June 1. As usually I plan on driving the car to the event, race it, and drive back.
1968 Beaumont
post #100 of 143 (permalink) Old Nov 20th, 19, 8:01 PM
Looks like a fun event. Although for a 'Midwest' event, it seems pretty far East to me. If you can make the 30 hour drive to the first track, I see no reason why you'd have trouble with the 'Drive' part of this 'Drag-N-Drive' event. We had a 'Drag Weekend' event here, quite a bit smaller though. Ours was Thunder Mountain in Kelowna Friday night, Drive to Osoyoos for a Wine Country Racing Association event Saturday, than back to Thunder Mountain for Sunday. Both are 1/8 mile tracks and 150km apart. I didn't find out about it until too late, we were busy that weekend, maybe next year. Always helps motivation when there is a goal with a set date. Good luck!
1969 Beaumont
1977 Bronco
The rest are boring responsible adult vehicles not worth mentioning.
Chris27 is offline
post #101 of 143 (permalink) Old Nov 28th, 19, 11:05 AM Thread Starter
Pretty slow the last couple of weeks. So recently I rebuilt the snout for the hydraulic throw out bearing. This is a slip on style hydraulic throw out bearing. It is made by Howe racing, It has performed really well with no problems. My old snout was a super t10 one I bolted up. The new one is a machined down T56 snout. The reason for the switch was to have a hub centric version for a little more accuracy.
ID:	609418   Click image for larger version
ID:	609422   Click image for larger version
1968 Beaumont
post #102 of 143 (permalink) Old Dec 1st, 19, 11:14 PM Thread Starter
Well first part in, harmonic balancer. Picked up a powerbond SFI 18.1 version. Really nice piece, elastomer style.
So through some discovery the 502 build got cancelled. Stay tuned for new build details!
ID:	609748   Click image for larger version
ID:	609750   Click image for larger version
1968 Beaumont
post #103 of 143 (permalink) Old Dec 3rd, 19, 11:37 PM Thread Starter
Well that was a intense job. New box restoration and new heater core. This aluminum unit is drastically lighter than the copper version. It needed some modish as the bottom port was directly inline with the 5” down pipe. So I cut and welded it straight, I will need to find a 90 degree bend hose to hook it up.
Brakes remain the same, installed new bearing. I didn’t see the point in buying a wok wood kit yet for a ‘maybe’ in braking performance and 10lbs weight loose. The funds will go to the engine.
So with the savings of the brakes, it just got forwarded to a new crank. 4.25” stroke will make it a 540 big block Chevy. The new pistons will allow for 15psi boost. Should be a torque monster! With that said I will be trying the aluminum flywheel again given a new found torque output, hopefully I don’t regret the decision.
ID:	609958   Click image for larger version
ID:	609960   Click image for larger version
ID:	609962   Click image for larger version
1968 Beaumont
post #104 of 143 (permalink) Old Dec 14th, 19, 10:21 PM Thread Starter
So out with the old and in with the new.
Built a new fuse/relay system for all the accessories. Probably a little over board for now but leaves some room for expansion. There is a total of 8 additional circuits, all on there own fuses and relays.
2-stereo amp
2-fuel pump
1-tach gauge
1-coil
1-coil driver
1-transmission reverse module.
The whole panel I put on hinges under the dash so that if you need to work on it, change fuses, or changes relays it will just swing down to complete the work. When not working on it, it just folds up underneath the glove box.
ID:	610706   Click image for larger version
ID:	610708   Click image for larger version
ID:	610710   Click image for larger version
1968 Beaumont
post #105 of 143 (permalink) Old Dec 16th, 19, 10:53 PM Thread Starter
Nice little sniper screen holder. This as well folds underneath the dash on hinges. It was built around the sniper cover meaning the screen can slide out of the holder if you want to hold it or pull the SD card out.
Built a little large for now but in the future there will be some switches mounted to it as well.
-SS454- likes this.
1968 Beaumont
