Chevelle Tech - View Single Post - battery dies but alternator is good
post #3 of (permalink) Old May 18th, 05, 11:18 AM
John_Muha
Re: battery dies but alternator is good
Try disconnecting the negative cable from the battery. Put a test light between the negative cable and the negative post of the battery. See if the test light comes on. It should not light up unless you have a clock or a modern radio memory.
John_Muha is offline
