Chevelle Tech - View Single Post - Ground straps
Thread: Ground straps
post #2 of (permalink) Old May 14th, 05, 12:58 PM
docaudio
Re: Ground straps
I've heard that the ground straps are for radio noise supression. You probably have a cable from battery negative to the engine. That's the electrical ground. It's also important to have a multi-point ground for the engine block to the frame. I've studied this setup and it looks like GM wanted the block grounded in more the one place to act like shield for the ignition system getting into the radio.
Almost original owner of '72 Elky SS - 415cu Motown, Stealth Ram EFI, AFR 210's, Hyd. Roller;
Baer 13" discs front/rear, 17" x45ZR tired "Grocery Getter" - I will get thing painted if it kills me...
-- also an '87 German Corvair (Carrera Targa - "The Heartbeat of Germany")
docaudio is offline
