Halo Headlights for 64-70! - Page 5 - Chevelle Tech
Sponsors Sales & Specials
post #61 of 88 (permalink) Old Dec 9th, 15, 8:52 AM Thread Starter
Banned
Re: Halo Headlights for 64-70!
The ring is built in, but with much higher quality components. We can sell just one as a replacement if need be also.
Ground Up is offline
post #62 of 88 (permalink) Old Dec 9th, 15, 9:01 AM
Rich
I've seen the APC ones in person. Wish you were closer to me so I could see yours in person too and might be interesting to compare them side by side.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #63 of 88 (permalink) Old Dec 9th, 15, 9:09 AM Thread Starter
Banned
These to the APC ones is night and day.
post #64 of 88 (permalink) Old Dec 9th, 15, 8:26 PM
Thanks Rich,
Your knowledge once again is appreciated!
Thank you Groud-Up for
your quick response to the group!
AldoNova67 is offline
post #65 of 88 (permalink) Old Dec 10th, 15, 8:41 AM Thread Starter
Banned
No problem
post #66 of 88 (permalink) Old Jul 17th, 16, 11:26 PM
Jorge
Originally Posted by Rich-L79 View Post
Correct me if I'm wrong, but one of the biggest differences between the ones Ausley's sells and the ones Ground Up sells is that that Ground Up versions allow you to replace the driving light bulbs without replacing the entire capsule containing the halo, correct? On the less expensive ones, if the halo or the driving light bulb fail you have to replace the entire sealed capsule. This might be a deciding factor at least partially determined by how much you drive the car you intend to put these lights into. Not sure how easy or difficult (or expensive) it is to locate a single sealed capsule for replacement on the Ausley's version. Of course if the halo fails on either version you have the same issue of locating a single replacement capsule.
There are two completely different brands of halo lights being discussed here.
Ground Up: Delta brand, replaceable driving light bulbs
Ausley's: APC brand, sealed capsules
Both have halogen driving light bulbs and halos in the capsule and look basically stock when lights and halos are off. The two magazine articles feature the APC brand versions but the install would apparently be the same for both.
Wait is this true? If I get the Ausley's lights, will I have to get an entire new light and not just a halogen bulb?
JSolo is offline
post #67 of 88 (permalink) Old Jul 18th, 16, 7:04 AM
Rich
Yes. I have a set of the APC lights and they are sealed capsules. If either burns out you have to replace the entire bulb/capsule.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #68 of 88 (permalink) Old Aug 13th, 17, 11:38 AM
I purchased a set of the new halo lights from Ground Up and they are a bear to get to fit. I have a 1969 Chevelle and started with the brights, those were difficult and then I started the Hi/Low lights and the alignment slots on the back of the lights do not line up with the light buckets so now I am dead in the water. Has anyone else ran into this issue? What's the fix?
DB MNR is offline
post #69 of 88 (permalink) Old Aug 13th, 17, 12:18 PM
Go back to stock style headlights.
RealRed70 is offline
post #70 of 88 (permalink) Old Aug 13th, 17, 4:19 PM
That thought did cross my mind, but they are here and I have probably had them long enough that I cant return them even though they are still in the boxes and to be honest I think they will look good with the flat black paint. Right now they are not looking all that great sitting there staring at me yelling, put me in...
DB MNR is offline
post #71 of 88 (permalink) Old Aug 13th, 17, 4:55 PM
Poor fit seems to be a universal problem with these aftermarket light kits. That's the reason I haven't made the leap,yet.
Clint44 is offline
post #72 of 88 (permalink) Old Aug 13th, 17, 5:21 PM
I ordered a set of Dapper Lighting 575 lights for my 66 Chevelle. Still waiting on them to arrive so can't comment on quality or fitment yet. Read a lot of good things about them and they have choice of different halos as well as the switch back option to be used as turn signals.
They have 7 Inch versions as well.
Dapper Lighting
jerems is offline
post #73 of 88 (permalink) Old Aug 14th, 17, 8:41 AM
Rich
The APC set I installed dropped right in the buckets without any issues at all.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #74 of 88 (permalink) Old Aug 14th, 17, 3:02 PM
Did you purchase those from Ausley's?
Clint44 is offline
post #75 of 88 (permalink) Old Aug 14th, 17, 3:29 PM
Rich
Yes.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
Tags
halo headlights , halogen , headlights
This Thread is more than 391 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
