JUST RELEASED - 1969 Chevelle DAKOTA DIGITAL RTX GAUGE SYSTEM! - Chevelle Tech
Sponsors Sales & Specials
 2Likes
  • 1 Post By MCB
  • 1 Post By MCB
post #1 of 10 (permalink) Old Feb 12th, 20, 2:18 PM Thread Starter
MCB
Matt
Send a message via AIM to MCB
JUST RELEASED - 1969 CHEVELLE DAKOTA RTX GAUGE SYSTEM!
We have 2 of these IN STOCK, ready to ship today! We are NOT allowed to show the price we sell these at, please message for your sale deal. List price is $1295 - NOT YOUR PRICE.
- Choose your illumination color
- Everything is controlled and setup with your smartphone
- Look is as close to original as possible
- Temp, oil and speed sensors included
- For LS/LT swaps, we have a plug n play interface module
- Fits in your stock bezel - BEZEL NOT INCLUDED
The RTX series is the latest from Dakota Digital, focused on retaining that stock look without sacrificing the late-model features you love. Every effort has been put forth to incorporate OEM design elements regarding the layout, face styling and indicators. A casual glance may dismiss these as original equipment, but once you hit the switch and the LED back lighting comes on in your favorite color scheme, all doubts will be removed.
Starting from scratch, CNC machined housings are filled with electronics designed and built in-house, helping Dakota Digital once again raise the bar for aftermarket instrumentation. The high-definition TFT message centers can be fully configured to display just about any piece of information needed. As you’ve come to expect from Dakota Digital, the RTX series utilizes a central control box to make installation and setup as easy as possible.
Please PM, Call, Email or text for pricing.
Call: 925-828-5555
TEXT ONLY: 925-989-9091
Email: [email protected]
MCB Parts
ID:	616360   Click image for larger version
ID:	616362   Click image for larger version
ID:	616364   Click image for larger version
MCB is offline
post #2 of 10 (permalink) Old Feb 14th, 20, 8:58 PM
Re: JUST RELEASED - 1969 Chevelle DAKOTA DIGITAL RTX GAUGE SYSTEM!
Is there a way to dim down the speedo gauge so it isn't as overpowering when lit up in the dare than the other gauges? I realize the numbers are are larger, but dimming may help compensate for a more leveled look.
'69 Malibu
Not2Fast is offline
post #3 of 10 (permalink) Old Feb 17th, 20, 11:44 AM Thread Starter
MCB
Matt
Hello,
Absolutely, you can purchase the DIM-1 to dim the light on the fly when your headlights are on, as your original headlight rheostat will not work. You can just mount the dimmer knob under the dash. The other option is you can change the brightness in the setup menu this will allow you to dim the back light illumination.
Hope this helps answer your question.
MCBparts
Not2Fast likes this.
MCB is offline
post #4 of 10 (permalink) Old Feb 17th, 20, 1:27 PM
They should have added numbers to the oil, battery, fuel, and temp gauges.
69SS454 is offline
post #5 of 10 (permalink) Old Feb 17th, 20, 3:06 PM Thread Starter
MCB
Matt
When the car is off there are no numbers displayed in those set of 4 gauges. Once it is powdered on the numbers will appear on all 4 of those gauges. We included an image of both on and off. Hope that helps answer your question.
Kim
MCBparts
69SS454 likes this.
MCB is offline
post #6 of 10 (permalink) Old Mar 3rd, 20, 10:20 PM
MCBparts
Can each gauge be dimmed separately, or do they all dim together? I'd be looking to just dim the speedo only.
'69 Malibu
Not2Fast is offline
post #7 of 10 (permalink) Old Mar 3rd, 20, 10:34 PM
Bruce
That is a very purdy setup.
Our You Tube Vids:
NickeyChevelle is online now
post #8 of 10 (permalink) Old Mar 4th, 20, 12:14 PM Thread Starter
MCB
Matt
No, they all dim together. I have never seen a gauge set where you can individually adjust each gauge.
Thanks,
MCB
MCB is offline
post #9 of 10 (permalink) Old Mar 4th, 20, 12:47 PM
blm
Couple questions.
I assume the display color can be changed?
Just inboard of fuel,temp,pressure, voltage displays there are little boxes. What are those?
No digital display for tach similar to speedo display?
blm is online now
post #10 of 10 (permalink) Old Mar 4th, 20, 3:11 PM Thread Starter
MCB
Matt
Couple questions.
I assume the display color can be changed? Yes, there are many colors to choose from and it is all done through the Dakota app on your smartphone.
Just inboard of fuel,temp,pressure, voltage displays there are little boxes. What are those? They are the TFT info screens. You can fully customize them to display whatever data you want.
No digital display for tach similar to speedo display? I have not seen where tach can be displayed digitally.
Here is a link to the instructions on the kit which go through every detail: https://www.dakotadigital.com/pdf/HDX_manual_main.pdf
Thanks,
MCB
MCB is offline
You may not post new threads
