Chevelle Tech - View Single Post - steering column help
post #1 of (permalink) Old May 7th, 05, 8:30 AM Thread Starter
pduncan
On my 67 Chevelle;
Due to a poorly installed column mounted tach that allowed the mounting screw to short out something inside, my turn signal assembly and harness needs replacing. It has fried and I am damn lucky I did not lose the whole car over this mistake.
I have the replacement now. The assembly itself looks identical but have some questions on the wiring.
The female connector under the dash has 8 terminals, with the following wires going into it. From left to right they are
white,green,yellow,purple,brown,dk blue(2),Lt blue(2),black
The male plug on my new harness has only 7
black,pink,Lt blue,white,dk blue,yellow,green
Do I have the right assembly? I see in my service manual seven wires going to the signal switch and an eighth going to the horn. Do I have to run this eighth wire seperate? I dont want to do any more damage.
Thanks in advance
Dunc
pduncan is offline
