1967 396 Chevelle with 402 badge on valve cover - Chevelle Tech
 8Likes
post #1 of 19 (permalink) Old Jul 11th, 16, 8:29 PM Thread Starter
I have confirmed the numbers on the bell housing to be a 1967 396 Chevelle by looking through info on this website and I have pics of everything I'll reference here. So the numbers on the bell housing are 3902406 and thats the first picture. The second picture is from the stamp on the front of the motor behind the alternator. And those numbers are I7144551. Now the last pic is of the valve cover with a 402 badge on it... I was told that this motor was a rare because it was a 396 block punched over to a 402 from the factory with a roller top end. I look forward to seeing what you guys have to say about it
Oh yea... What's it Worth
Name:	engine id by bell housing.jpg
ID:	373306   Click image for larger version
ID:	373314   Click image for larger version
Name:	402 badge.jpg
Daniel Hehir is offline
post #2 of 19 (permalink) Old Jul 11th, 16, 8:59 PM Thread Starter
Re: 1967 396 Chevelle with 402 badge on valve cover
And of course the pic of the id stamp behind the alternator is blurry I might have to get a better one tomorrow by taking the alternator off...
post #3 of 19 (permalink) Old Jul 11th, 16, 9:27 PM
Sean
Someone bought a sticker and made up a story....
swilk427 is offline
post #4 of 19 (permalink) Old Jul 11th, 16, 9:43 PM
Ron
I hope you aren't buying that story. Nothing is correct "factory" in that pic. engine painted black, tall valve cover, alternator on wrong side. You can buy stickers anywhere.
Daniel Hehir likes this.
70 Chevelle SS396 (496) Straub roller, 700r4
69 Malibu convertible (sold)
TC #54 Gold
ToocoolZ28 is offline
post #5 of 19 (permalink) Old Jul 12th, 16, 1:25 AM
yeah, obviously NOT stock or original...
First, its an air cleaner decal. Second, that decal was NOT available until at least late 1969 (when Chevrolet created the "production" 402). IIRC, Chevelles still used the "396" decals and the full-size/Impalas referred to the engines as "400", so IIRC, it was the pickups that used the "402" decal...
ALL 402's are 0.030 overbored 396's... Lots of stories as to why Chevy went with the larger bore...
Roller topend? I would say 99.9% untrue... IF Chevy was going to use "roller top end" on this alleged '67 402, then why wouldn't they use it on the 427 (L88 etc) or the LS6???
As someone mentioned, the alternator is on the wrong side. Chevy didn't put the alternator on that side, OR use a "long water pump", until the 1969 model year... What purpose would that serve???
What's the other numbers stamped on the front pad (should start with "T####" etc...)
"I7144551"
I, there was NO assembly plant used the letter "I", but St Terese Canada used a "1", and sometimes "I" and "1" stamps were used interchangeably. For 1967, the only cars built at St Terese and using a 396 (###406 block casting) would be full-size cars. St Terese did NOT build Chevelles in 1967... That would probably make it a 325HP 396, 2-bolt mains with oval port heads...
Looking at the pictures
Well, assuming its got standard oval port heads (they do appear to be pre-69 heads, at least the one pictured) and two-bolt main caps (you didn't say or include other pictures), then I'd guess its worth between $200 and $1200, depending on if its running or not... It doesn't look like it, so I'd guess $200-$500 (while not correct for 1967, it may be fairly complete).
Basically, its "just" a 396... An an Impala (or truck) will need a different oil pan to fit a Chevelle.
Now IF it has the "factory" 4-bolt main block, I'd add another $750-$1000... Rectangle port heads, figure another $500+ (depends on condition and casting numbers).
Looking at the pictures, it looks like its in a truck right now...
TC #1366
Sold
Sold
1966_L78 is offline
post #6 of 19 (permalink) Old Jul 12th, 16, 8:21 AM
Welcome Daniel, to Team Chevelle.....
Agree with the last 3 posts. Someone is feeding you a line of BS to sell you their engine. That's not to say the engine is no good, it's just not "right" with what the seller is telling you. The 402 sticker on the valve cover is just.....
That's one reason this site is great; to get correct info on a possible purchase.
When I works, I works hard.
When I sits, I sits loose.
augy is offline
post #7 of 19 (permalink) Old Jul 12th, 16, 10:48 AM
Robert
And 396-402 are not as popular as they use to be, so the prices are down.... Don't believe everything you hear and take everything with a grain of salt.
'67 Elky Global West suspension kit with coil over QA1's, 435hp Edy Crate,700R4, Currie +9 3:75, Disc brakes front and rear, Dakota Digital gauge package, 12 Circuit Painless wiring kit, Ididit tilt Colum, etc.
2012 HD Tri-Glide in Vivid Black.
1967 XR7 Cougar S code 390.
2016 Charger R/T in Purple.
rak1 is offline
post #8 of 19 (permalink) Old Jul 12th, 16, 2:00 PM
Figure a 396/402 is typically going to be less desireable and less valuable than a 454 in similar condition... Those that just have to have a "correct" 396 are not the majority...
TC #1366
Sold
Sold
1966_L78 is offline
post #9 of 19 (permalink) Old Jul 12th, 16, 4:22 PM Thread Starter
Can I post some more pics of the heads for you to determine if they are rectangle port or not? If so from which angle should I take the photo? And as far as the 2 or 4 bolt mains go, I'll have to just take the oil pan off and look at them. I really appreciate all the insight! Thank you guys!
post #10 of 19 (permalink) Old Jul 12th, 16, 4:33 PM
You could pull one or both valve covers, then post the part numbers and date code. That way you will be certain of your valve train and what heads you have.
Steve R
Steve R is online now
post #11 of 19 (permalink) Old Jul 12th, 16, 4:37 PM
Post some pictures where the intake meets the heads, between the carb and the thermostat housing. May be able to determine rectangular versus oval ports, but it depends on the intake used... you may need to pull the valve covers to get the casting number. From the angle of your previous pictures, it looks like an oval port intake and head (but not a great shot).
Also a picture of the head above the headers/exhaust but below the valve covers, mid-way down either side, right were the dip stick is... Actually, you'd be looking for a fitting in the head, right where the header flange dips in the middle. This won't determine rac/oval, but pre-69 heads do NOT have a fitting, maybe a flat boss... Later heads have a fitting for the temp guage right above the exhaust flange.. so "1967" heads won't have the fitting.
Originally Posted by Steve R
You could pull one or both valve covers l, then post the part numbers and date code. That way you will be certain of your valve train and what heads you have.
Yeah, you could see if it NOW has a roller "topend", etc. Or if its just regular valvetrain...
4-bolt main: Not foolproof but 99+%, post a picture of the area right above the oil filter. There are some fittings there, oil pressure light/guage sending unit... Those "typically" can determine 2-bolt or 4-bolt mains (not fool proof, but never seen it vary)... 4-bolt blocks have two larger plugs/fittings for oil cooler fittings on HD blocks...
Also, get another picture of the pad behind the alternator...
There should be other numbers there beside just the "17144551" Something like "T0123 IG"... Should start with "T" followed by 4 digits, and then followed by another 2 letters (maybe 3, but doubtful)...
TC #1366
Sold
Sold
1966_L78 is offline
post #12 of 19 (permalink) Old Jul 12th, 16, 7:51 PM
That's an Edelbrock intake which should have a part number on it.That would tell you what intake type would be, oval or rectangle port and give a hint to what the heads are.Of course some people put ovals on rectangle so its not proof positive but if they won't let you pull a VC ....
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is online now
post #13 of 19 (permalink) Old Jul 18th, 16, 12:14 AM Thread Starter
Here's a pic from between the carb and intake. The intake says its an edelbrock performer 2-0
Then I got pics of the Head casting numbers, and the center by dipstick along with the driver side.
Then pics of the remote hookups for the oil filter, and the oil pressure sending unit.
Only thing I couldn't find was any more numbers behind the alternator. I know there's no more numbers on that pad, but if they are somewhere else I could look again.
ID:	374562   Click image for larger version
ID:	374570   Click image for larger version
ID:	374578   Click image for larger version
ID:	374594   Click image for larger version
ID:	374602   Click image for larger version
ID:	374610   Click image for larger version
ID:	374626   Click image for larger version
post #14 of 19 (permalink) Old Jul 18th, 16, 12:19 AM Thread Starter
Thank you guys again for your time and knowledge I own this motor its in a 1 ton truck right now with a turbo 400 3 speed automatic.
post #15 of 19 (permalink) Old Jul 18th, 16, 12:47 AM
The heads are oval port. I hope it turns out to be a decent running engine for you.
Steve R
This Thread is more than 1160 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
