66 12-bolt value - Chevelle Tech
 2Likes
  • 1 Post By PMG
  • 1 Post By 64tempestwagon
post #1 of 8 (permalink) Old Dec 8th, 19, 11:44 PM Thread Starter
PMG
66 12-bolt value
I have a 66 A-body 12-bolt in great shape, no pits, clean steel painted black, currently under a driving A-body. It is originally a 3.73 posi rear. I have the original Chevy posi case and axles, but have upgraded the axles to Moser C-Clip axles and a newer 400 lb Eaton posi case is also installed. It also has an original Tomazewski (TA Performance) aluminum cover girdle with preload bolts for the bearing caps. The gears are original Chevrolet. The casting number is 3875745 N. The axle tube stamping is CI 0331 B with an E under it. Looks like a 66 Chevelle rear from '66, assembled in Buffalo on March 31, 1966.
Can anyone give me a value range for this piece? Thank you. Pat
senna likes this.
PMG is offline
post #2 of 8 (permalink) Old Dec 9th, 19, 7:50 AM
Re: 66 12-bolt value
I sold one earlier this year. the code was 3.31 posi, but sometime in the past a set of 3.50 (yes 3.50 35 ring gear, 10 pinion) gears were installed. I got $1400 for it. Buyer had a numbers matching 66 that was missing the original 12 bolt a d was specifically looking for a early dated housing. jim
Jim Mac is offline
post #3 of 8 (permalink) Old Dec 9th, 19, 9:27 AM
X2 ^^. Possibly more to the right buyer. Good Luck.
USAF Retired (1968-1988)
David Bates is offline
post #4 of 8 (permalink) Old Dec 9th, 19, 10:10 AM
Keith
Makes me feel great after paying 1200 for a rebuilt one 14 years ago
Maryland Chevelle Club #682
keithb is offline
post #5 of 8 (permalink) Old Dec 9th, 19, 12:41 PM
The numbers above are in the ballpark, but where you live will be a factor. If you live in a large urban area with a lot of potential buyers you will likely get more, if you are located in the middle of nowhere you will likely get significantly less.
Steve R
Steve R is offline
post #6 of 8 (permalink) Old Dec 10th, 19, 2:44 AM
steve
I paid $1200 for a 67 Chevelle correct 12 bolt 3.73 posi complete 2 years ago in Los Angeles
fr8dog likes this.
64tempestwagon is offline
post #7 of 8 (permalink) Old Dec 10th, 19, 7:58 AM
Depending on where you live. Pat what area are you in?
USN-SSBN 645-G
boyd66k20 is offline
post #8 of 8 (permalink) Old Dec 10th, 19, 12:52 PM
I'd be interested in it if your west of the Mississippi.
jjump59 is offline
