1970 454 ls3 date h20 9 - Chevelle Tech
 2Likes
  • 1 Post By 70SSTHUMPER
  • 1 Post By lrdvdr41
post #1 of 13 (permalink) Old Dec 2nd, 19, 10:06 AM Thread Starter
Question 1970 454 ls3 date h20 9
Hello, I have a 454 LS3 with a date of Aug 20 1969. it is complete except for the Quadrajet. It runs but needs valve stem seals for sure. It has around 89,000 original miles and has been in my shop for nearly 30 years. I am wondering why I saved it this long and what it may be worth if I were to sell it. Any advice would be greatly helpful. Thanks to anyone who can give some info.
ID:	609756   Click image for larger version
70 L 78 396 is offline
post #2 of 13 (permalink) Old Dec 2nd, 19, 10:14 AM
RonO.
Re: 1970 454 ls3 date h20 9
LS3 is a 402, not a 454. Also, it would be good to pop a valve cover and type the head casting and dates. The suffix code should be typed also, these photos don't really help much.
RealRed70 likes this.
1970 Chevelle 517 cid, TH400, best ET mid 9's. #19.
70SSTHUMPER is offline
post #3 of 13 (permalink) Old Dec 2nd, 19, 11:18 AM Thread Starter
OK, I am 71 and my memory is not the best when it is something that I have not messed with for awhile. The number stamped on the block pad at the pass. side front is TO822CGV which indicates a 454.
post #4 of 13 (permalink) Old Dec 2nd, 19, 11:27 AM Thread Starter
the casting date inside the r valve cover is G30 9 (July 30 1969) the casting number at the other end is 3984290
post #5 of 13 (permalink) Old Dec 2nd, 19, 4:35 PM
Randy
The 290 heads and the date code on them make sense. They were on some 69's and 70's. Oval port heads. Would you have a photo of that block stamp?
redrocket1953 is offline
post #6 of 13 (permalink) Old Dec 2nd, 19, 5:35 PM
Randy
Also what is the casting number on the block?
post #7 of 13 (permalink) Old Dec 2nd, 19, 7:40 PM
What you have there is probably a LS4 "512" 2 bolt block (3963512).
(VIN may be stamped by the oil boss)
Stickman is offline
post #8 of 13 (permalink) Old Dec 2nd, 19, 8:40 PM Thread Starter
Like I said earlier I had forgotten about the series LS 3,4 or 5 because I have accumulated all of them including a 6, which is long gone. But the casting # is H20 9 which is Aug 20 1969 and the Stamped ID # is TO822CGV. That # is on the pass front block pad. I haven't looked for a # near the oil boss. I will try to include a pic.
Name:	eng stamp 1.jpg
ID:	609812   Click image for larger version
Name:	block date casting 1.jpg
Last edited by 70 L 78 396; Dec 2nd, 19 at 8:43 PM. Reason: trying to add a picture
post #9 of 13 (permalink) Old Dec 2nd, 19, 9:19 PM
RonO.
CGV is a 1970- 454, 345hp Manual- LS-4 I like the 290's, used on LS5 also. Provided this motor is a rebuildable core and not knowing the block casting #I'd put you at between 800-1800.00, what is the intake #? If you can get that VIN # off of the deck, that could be your money maker.
post #10 of 13 (permalink) Old Dec 2nd, 19, 9:34 PM
Randy
Now just a block casting number will tell the story. Should be on the rear top of the block by where the bell housing bolts up.
post #11 of 13 (permalink) Old Dec 3rd, 19, 12:25 PM
Anakin
It's a 512 454 block, complete unmolested pullout from a 70 caprice. You'd probably get 2500-3000 on ebay.
lrdvdr41 is offline
post #12 of 13 (permalink) Old Dec 4th, 19, 10:49 AM
RonO.
Wondering how you came to this conclusion without a casting # provided by OP? No Vin stamp? ( Could be a Corvette motor?) How can you call it complete without original carb: (7040200EE), no intake casting info by OP( 3855287), No Exhaust Manifold info: (should be: Left Side: 3914613 Exhaust Manifold Right Side: 3916178): Thermostat Housing: 3877660.
And how can you call it "Unmolested" without a complete teardown and hands-on inspection?
post #13 of 13 (permalink) Old Dec 4th, 19, 2:02 PM
Anakin
Because I helped him pull it out of the car in November 1990.
redrocket1953 likes this.
lrdvdr41 is offline
