1967 Malibu - Chevelle Tech
 10Likes
  • 4 Post By blm
  • 2 Post By Pete 67
  • 1 Post By budgey
  • 1 Post By budgey
  • 2 Post By 1967 chevelle malibu
post #1 of 12 (permalink) Old May 24th, 19, 8:40 AM Thread Starter
1967 Malibu
I have a few photos. 350 motor, solid frame, floors and trunk (I'm told). Runs and drives. Asking 12.5k. What do you guys think?
Name:	Screenshot_20190522-044425_Samsung Internet_1558698074513.jpg
ID:	594232   Click image for larger version
ID:	594234   Click image for larger version
Name:	Screenshot_20190524-073552_Samsung Internet_1558698104571.jpg
budgey is offline
post #2 of 12 (permalink) Old May 24th, 19, 9:55 AM
Re: 1967 Malibu
similar to my 66 (mines a 4 speed 12 bolt) I wouldnt let mine go for less than $12,500. jim
Jim Mac is offline
post #3 of 12 (permalink) Old May 24th, 19, 10:11 AM
blm
Re: 1967 Malibu
Personal inspection of condition of body/frame/paint condition is mandatory. Much depends on that.
blm is offline
post #4 of 12 (permalink) Old May 24th, 19, 1:36 PM
Re: 1967 Malibu
I think if you want 12.5 for that car, you might want to take better pics.
Steve R and LeoP like this.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #5 of 12 (permalink) Old May 24th, 19, 2:23 PM
Greg.
Re: 1967 Malibu
For a SBC it should have the Extra/Spacer Bracket between the Rad and the Front End Cross Member/ Rad Core Support.
Here is a pic of mine when I first bought my 67 Chevelle
Here is what it looks like by itself
As it is installed on the Rad Support Panel in a empty Engine Bay
However since the SBC in your 2nd pic has a Serpentine Style Pulley System I guess there was not enough room/space for it
If there is not too much Bondo in the Quarters etc. and the Floors are good
then $12.5 is reasonable IMHO
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #6 of 12 (permalink) Old May 24th, 19, 2:33 PM Thread Starter
I don't own this car. I'm thinking about buying it. 12.5k is the asking price.
427L88 likes this.
budgey is offline
post #7 of 12 (permalink) Old May 24th, 19, 2:46 PM
Re: 1967 Malibu
Floors, trunk and the rear window are the 67's "special areas". 12.5 is reasonable if it isn't a bondo queen. Take a magnet, and Budgie, go... " IN FOR THE KILL" at 10k.
Budgie is an old rock band I used to like.
post #8 of 12 (permalink) Old May 24th, 19, 3:53 PM Thread Starter
Thanks 427.
427L88 likes this.
budgey is offline
post #9 of 12 (permalink) Old May 24th, 19, 7:56 PM
gary
Re: 1967 Malibu
Get in the trunk & look up at the rear window area from beneath it.
427L88 and JDV like this.
post #10 of 12 (permalink) Old May 24th, 19, 9:05 PM
Re: 1967 Malibu
Go over it with a fine tooth comb. The engine looks like it was dressed up with whatever they had lying around or found for cheap at the swapmeet. Primer hides a lot of problems. If itís straight and the quarters, trunk pan and floors donít need work, it might be fair. If there is a bunch of Bondo or rust in the quarters or rocker panels, walk away and wait for something better to show up.
Steve R
Steve R is offline
post #11 of 12 (permalink) Old May 24th, 19, 9:55 PM
Re: 1967 Malibu
I'd do the same for the lower front windshield area... Bring a flash light and look up...
When you are in the trunk, also check the insides of the quarter panels, for damage...
It all depends on the individual, but personally, rusted floors aren't too much of a worry... Easily patched (usually), and hidden by the carpet, etc... The the window channel rust that needs to be fixed first...
TC #1366
Sold
Sold
1966_L78 is offline
post #12 of 12 (permalink) Old May 29th, 19, 7:28 AM
sam
Re: 1967 Malibu
As stated, check it out really well. Car is still in primer and the add says it needs body work before paint. It also depends what your plans are with the car. The vin is not in the add, so did it start as a 6 cylinder car. Canít see the V on the emblems. What rear end? I see itís in Camillus, are you close?
1967 Royal Plum, 434BB, AFR Heads, 3.90 gears, New Chris Straub Hyd Roller!, 200r4
scalise71 is online now
1967 malibu speedo lens PARTSCHEV2 Interiors 1 Nov 23rd, 16 6:16 PM
Nice Gold 1967 Malibu Driver - What's it worth? JimmyS72 What's it worth? 8 May 23rd, 16 12:39 AM
1967 Malibu Conv. stock0823 What's it worth? 4 Aug 14th, 15 3:03 PM
1967 Malibu Cowl Tag SS454MIKE Tag Team 3 Sep 16th, 14 9:47 AM
1967 Chevelle Malibu or 1967 Chevelle SS Ken's Email Tag Team 10 Jan 7th, 13 1:17 AM
