1970 Chevelle SS maybe - Chevelle Tech
 3Likes
post #1 of 21 (permalink) Old Mar 28th, 19, 1:25 PM Thread Starter
I bought a 1970 Chevelle represented as an SS and only have the Vin, is there a way, without ripping up the carpet, i an tell if it is a true SS? Almost everything that has or would have had a code has been upgraded. I know that the vin will probably not help due to it changing from a production SS to a option in 1970 but included it anyway.
I have searched for documentation but have been told by several sites that nothing is available due to a fire pre 1977.
If you know a way or a site i can pay for more info on my car it would be greatly appreciated.
Vin: 136370L6156470
Thanks,
post #2 of 21 (permalink) Old Mar 28th, 19, 1:50 PM
Troy
Re: 1970 Chevelle SS maybe
According to the vin it's Van Nuys built car. Drop the fuel tank. More than likely a build sheet glued to the top.
70 L34 M20 VERT 28-A 791
70 LS5 M22 COUPE 58-58 756
70 LS6 M40 COUPE 14-14 756
70 L?? M?? COUPE 926-99616-755
69 L78 M21 COUPE 71-B 756
blacknblue is offline
post #3 of 21 (permalink) Old Mar 28th, 19, 1:56 PM
blm
For 1970 Chevelle the only verification of being an SS is a numbers matching big block engine, a Protect plate or a build sheet.
If you just want to search your cars history and as long as it is not an Atlanta built 70 you can contact NCRS. For a fee they will send you a shipping data report which will tell you the exact date of manufacture and the original dealer that the car was shipped to. In most cases that dealer was the one that sold the car new.
EdCarpenter likes this.
blm is offline
post #4 of 21 (permalink) Old Mar 28th, 19, 2:13 PM Thread Starter
How much would a shop charger for that, ballpark?
post #5 of 21 (permalink) Old Mar 28th, 19, 2:14 PM Thread Starter
I already did that and this is the info i received, the dealer is out of business. Anything you can get from this?
William - The shipping data information for your 1970 Chevelle is:
Production Date: 2/15/69
Dealer Zone: #36
Dealer Code: #681
Dealer Name: Westland Chevrolet Inc
Dealer Location: Thompson Falls, Montana
The hard copy report will be mailed tomorrow.
Thank you for using the NCRS Expedited Shipping Data Service
post #6 of 21 (permalink) Old Mar 28th, 19, 2:32 PM
It depends on what labor rates are in your area. Where I live, itís well over $100/hr. Figure you will get charged at least a couple of hours.
Steve R
Steve R is offline
post #7 of 21 (permalink) Old Mar 28th, 19, 3:36 PM
blm
Dealer Zone: #36
Dealer Code: #681
Well I am not suprise the dealer is out of business. I would imagine the vast majority of dealers.from 1970.are out of business. But that gives you a starting point. If you want to find out more about your car I'd take.that information found and run with it.
It may take leg work, persistence and luck but maybe you can find the original owner. Or you could start with person that you purchased the car from and go backwards.
I started with the 4th owner of my 69 and went backwards. Made it all the way to the original owner and got stories from all. I also found a newspaper from the local newspaper in the town that my original dealer was located in from Sept 10th 1969 that featured MY 69 being sold as a new car. Never know unless you try.
blm is offline
post #8 of 21 (permalink) Old Mar 28th, 19, 3:42 PM
blm
You know dropping your tank is not that difficult. You don't have to take it all the way down, just far enough to either get your hand up there or look up there with a mirror and flashlight. Just remember the less gasoline in the tank the better.
blm is offline
post #9 of 21 (permalink) Old Mar 28th, 19, 3:43 PM
There were non SS cars in 70 with big blocks
RealRed70 likes this.
post #10 of 21 (permalink) Old Mar 28th, 19, 4:00 PM
That production date must be 12/15/69, not 2/15/69.
70 LS5 convertible
12stones is offline
post #11 of 21 (permalink) Old Mar 28th, 19, 4:04 PM
Even if you track down the original owner, if he/she doesn't have the original paperwork on the car (or knows where the born with motor is) your still out of luck. A story from the "original owner" doesn't provide the proof you need to state your car is an SS from the factory. Your best bet is to hunt for the build sheet. Assuming you still have the original tank ... run most of the fuel out of it, loosen the 2 bracket bolts holding the tank in place down to where you can get a light/mirror to see if a Build Sheet is there -- pretty quick and easy. I found mine in my backseat (easy to pull) but mine is a Baltimore Built car.
Some cars the build sheet is long gone or never placed in the car since it was supposed to be trashed, it is what it is at that point ... just enjoy the car.
TC Member # 5462
70 Chevelle SS/396 4-Speed
DYNO RWHP: 364HP @ 5200 RPM / 426 Torque @ 3500 RPM
Birddog1970 is offline
post #12 of 21 (permalink) Old Mar 28th, 19, 4:07 PM
If the tank has never been dropped there is a real good chance some of the build sheet is still there. Good luck.
The build date puts it in the ball park for a LS-6 car.
AC or non AC?
What engine is in it now?
edspdog is offline
post #13 of 21 (permalink) Old Mar 28th, 19, 4:34 PM Thread Starter
AC or non AC?
AC and 454 crate.
Thanks,
post #14 of 21 (permalink) Old Mar 28th, 19, 4:39 PM Thread Starter
AC or non AC?
AC and crate motor.
Thanks,
post #15 of 21 (permalink) Old Mar 28th, 19, 7:07 PM
Not a LS-6 for sure.
No paper work and no owner confirmation, can't prove what it was born as.
Paper work can be faked and word of mouth don't mean much. Original owner could be long gone.
"Correct" original papers and matching stories are a plus.
Drive train numbers and SS tell tale signs are a good indicator but not absolute.
Still could find what it was on the gas tank.
edspdog is offline
What would it cost to restore this Rare SS454 Chevelle ysr_racer Bench Racing 16 Jul 13th, 18 9:36 AM
1970 Chevelle Restoration toocrazy Projects & Builds 140 Oct 12th, 13 9:02 PM
1970 Chevelle SS......Ivory or Pearl Interior Color? toocrazy Interiors 5 Jun 6th, 13 8:18 PM
1970 Chevelle Radio???? Davila2 Chevelle Tech 8 Dec 31st, 12 1:44 PM
