Chevelle Tech - View Single Post - Help Hooking up Push button Start
post #2 of (permalink) Old May 16th, 14, 9:47 AM
oldcutlass
Re: Help Hooking up Push button Start
If your doing it for theft prevention, I wouldn't waste my time. These old cars are easy to hot wire as all you need is a jumper from bat+ to coil + which will negate anything you do to the stock ignition wiring.
I use a ford style starter solenoid which is mostly to cure heat soak issues. From there you can wire in a push button start.
oldcutlass is offline
