Chevelle Tech - View Single Post - Weird grounding block bolted to firewall
post #37 of (permalink) Old May 9th, 14, 8:30 PM
todztoyz
todd
Re: Weird grounding block bolted to firewall
Originally Posted by Bikebro View Post
Any info on that wire that plugs into the distributor? What is its function?
If you're talking about the one at your finger and thumb....I believe that would be your 12 volt ignition wire. See where it is hooked up under the dash. It should go to switched 12 volt power. Someone please correct me if I'm wrong. On my 69, there is a nice lug in the fuse box for it.
todztoyz is offline
