Chevelle Tech - View Single Post - Rear left wheel locked up
post #22 of (permalink) Old Mar 16th, 14, 10:29 PM
Chris R
Re: Rear left wheel locked up
Check to make sure the adjuster is turned all the way back in. Also make sure the shoes are even with each other like this ( ). If one is off center the drum wont go on. Finally, it may be necessary to loosen up the parking brake cable adjustment as well. If rust isnt much of a problem where you live, then loosening it up shouldnt be too much of a problem. In the rust belt, you might as well pack a lunch when it comes to loosening up the parking brake cable.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Chris R is offline
