Chevelle Tech - View Single Post - Wipers to park
Thread: Wipers to park
post #7 of (permalink) Old Feb 25th, 14, 8:38 AM
daddio65
Re: Wipers to park
Originally Posted by hoopsnut View Post
There is a small set of points that open and close that open the ground on the park circuit. That was my problem. They are located under the washer pump inside. There is a small 1/8 inch hole just above the ground strap in the pic. The points can be seen through this hole. Just make it a bit larger and you can clean the points up.
Thanks a ton, I will get it fixed asap!!!
daddio65 is offline
