My 65 LS Swap Project - Page 8 - Chevelle Tech
Pro Touring Todays performance with classic style
 79Likes
post #106 of 148 (permalink) Old Jan 27th, 20, 4:09 PM Thread Starter
Re: My 65 LS Swap Project
I was just trying to figure out what I should've bought instead, but at the time I pulled the trigger on this didn't have enough knowledge to have made that decision.
Jeff Evans
65 Chevelle, LS3/T56 transplant in progress
67 Chevelle, ZZ502, AFR 305, Straub Solid Roller, 400 Turbo, Moser Rear 3.42 gear
Jeff65SS is offline
post #107 of 148 (permalink) Old Jan 30th, 20, 9:20 AM Thread Starter
Custom driveshaft arrived a few days ago so I got it installed last night. Its from the Driveshaft Shop, it has a CV joint on the trans end to allow for bad driveline angle that a lot of A body swap cars end up with. The best working angle I could get was 4.5 degrees at the trans end, due to the low rear stance and the T56. It was almost double the cost of a U-joint aluminum custom driveshaft, but I didn't want to raise the rear of the car or fight clearance in the driveshaft tunnel so I guess/hope its worth it.
More wiring tonight, hoping to have it completely wired by next weekend.
ID:	615026   Click image for larger version
Dan65ss, 66promalibu and rmc65elco like this.
Jeff Evans
Jeff65SS is offline
post #108 of 148 (permalink) Old Jan 30th, 20, 6:19 PM
Well, I'm a wee bit envious. TC member andrewb70 has nothing but praise for their CV joint driveshafts. You've made a wise choice I think and there is one in my El Camino's future also!
Jeff65SS likes this.
USAF Retired (1968-1988)
David Bates is offline
post #109 of 148 (permalink) Old Jan 30th, 20, 9:35 PM
Driveshaft looks great. How much was it? I may be needing one someday.
67
70 (SOLD)
Alwhite00 is offline
post #110 of 148 (permalink) Old Jan 31st, 20, 10:40 AM Thread Starter
Dave, Andrew's posts were how I found out about this product as well. I was disappointed after using the whole Holley/Blackheart kit components for a LS swap 64-67 A-Body to find that I still had around 5 degrees working angle on the front joint. I don't think the cars they used were as low as mine in the rear. I could have moved the tail shaft up some.... maybe 1/4" - 3/8" but that still wasn't enough to be able to use a standard joint plus I would have been very close to rubbing in the driveshaft tunnel. I think if I were building from scratch and had used a 9" Ford rear end rather than a 12 bolt it may have changed the front working angle enough to work. The pinion location on a 9" is much lower on the case vs. a 12 bolt.
Maybe my wise choice happened to be my only choice in the end!
Jeff Evans
Jeff65SS is offline
post #111 of 148 (permalink) Old Jan 31st, 20, 10:42 AM Thread Starter
Are you ready for this?...... North of $1100!
Jeff Evans
Jeff65SS is offline
post #112 of 148 (permalink) Old Jan 31st, 20, 10:45 AM Thread Starter
Vintage Air wiring completed last night. Onto radio and speaker wiring next. Then route A/C hoses under dash.... there's not a lot of room left under there!
Jeff Evans
Jeff65SS is offline
post #113 of 148 (permalink) Old Jan 31st, 20, 11:18 AM
Holy [email protected]#k! Ok, I'll work on getting mine dialed in.
67
70 (SOLD)
post #114 of 148 (permalink) Old Jan 31st, 20, 4:10 PM
Michael
I know what you mean, had to do mine twice to get custom lengths right.
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
post #115 of 148 (permalink) Old Feb 1st, 20, 10:56 AM
Great build! I put a Vintage Air in my '65 El Camino. To avoid two kinks in one of the heater hoses, I bent a coat hanger , went to O'Reilly's, and picked out a pre-formed heater hose that had a section in it that worked. Also had to cut a larger hole in the plastic kick panel to avoid a kink in one of the A/C hoses. (And don't forget the drain line thru the firewall. I nearly did.)
Thanks for posting the CV joint info. I struggled to get the pinion angle set and will have to check after I get some miles on the car. The Tremec ap on my iPhone shows 3.5 degrees (LS3 - TKO-600) after installing spacers on the cross-member.
Keeping going!
'65 El Camino - LS3
rmc65elco is offline
post #116 of 148 (permalink) Old Feb 3rd, 20, 3:52 PM Thread Starter
Keeping going!
I also bought a molded heater hose with a couple of 90 degree bends to get the upper heater hose out thru the kick panel without kinking. But I cheated, my friend had put vintage air in his 65 last summer and he had the part number of the hose!
I still need to run the drain hose, thinking about going thru the kickpanel rather than thru the firewall. I believe there are drain holes in the outer cowl where the kickpanel vents plug into.
rmc65elco likes this.
Jeff Evans
Jeff65SS is offline
post #117 of 148 (permalink) Old Feb 6th, 20, 1:51 PM Thread Starter
Some more pieces of the puzzle arrived yesterday.....
TMI seats!
Also got rear seat cover with matching pleat pattern.
Headliner, visors and sail panels will be black to match the 2 tone exterior. Package tray, dash and tops of doors will be red. Should closely resemble the exterior when completed.
I already have newer door panels, plan to find a SEM dye color that closely matches the TMI Red vinyl and spray those.
Dan65ss and senna like this.
Jeff Evans
Jeff65SS is offline
post #118 of 148 (permalink) Old Feb 6th, 20, 5:11 PM
And that part number/supplier would be . . . . . . . . . . Inquiring minds want to know!
post #119 of 148 (permalink) Old Feb 6th, 20, 9:58 PM
Here ya go:
Name:	Upper Inside Cab Heater Hose.jpg
David Bates likes this.
'65 El Camino - LS3
post #120 of 148 (permalink) Old Feb 6th, 20, 10:27 PM
Troy
TMI seats!
I go back and forth on these seats, some parts of them I like, some I don't.
I wish they could dial down that logo. Looks like they offer pretty good support, which really helps you enjoy the drive.
Either way, they'll look good in your car.
Sent from my SM-T720 using Tapatalk
66 CHEVELLE
senna is offline
