My 65 LS Swap Project - Page 5 - Chevelle Tech
Pro Touring Todays performance with classic style
 29Likes
post #61 of 76 (permalink) Old Mar 8th, 19, 9:35 AM
Re: My 65 LS Swap Project
Originally Posted by Jeff65SS View Post
None at all, but haven't driven it yet either. It had no noticeable smell when new out of box. Hope as it heats up it remains the same!
Right on, I pulled the trigger on a box. How much did you need to get the covereage you pictured? 1 box? 36sq/ft?
90lxracer is offline
post #62 of 76 (permalink) Old Mar 8th, 19, 9:38 AM
Move your jackstands to the a-arms and make sure all your clearances are still good, I'm warning ya for the last time!!
Jeff65SS and andrewb70 like this.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #63 of 76 (permalink) Old Mar 11th, 19, 11:20 AM Thread Starter
Moved to A-arms this weekend!
Dan65ss and Hotwire like this.
Jeff Evans
65 Chevelle, LS3/T56 transplant in progress
67 Chevelle, ZZ502, AFR 305, Straub Solid Roller, 400 Turbo, Moser Rear 3.42 gear
Jeff65SS is offline
post #64 of 76 (permalink) Old Mar 12th, 19, 10:05 AM
Glad to hear it. You notice how much flex your frame has now?
I learned the hard way, was hoping you'd move the stands before it was too late.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #65 of 76 (permalink) Old Mar 21st, 19, 3:41 PM Thread Starter
Updates from the last several weeks.
Most of my work was centered on the clutch master, brake master mounting and throttle pedal. Had a bitch of a time getting Modern Driveline clutch master pushrod to fit into small space. They use a hemi joint and a special adapter to bolt it to pedal. Adapter didn't fit without alot of grinding and hemi hit the bottom of the pedal box structure. Had to cut away part of the pedal box so pedal would swing correctly. Next challenge was the master would bottom out before getting anywhere close to the floor as was suggested in the instructions. Had to build an adjustable pedal stop to avoid ruining the master. You'd think they could engineer this better. They had to know this would be required if they actually installed this on a 64-66. Lokar throttle pedal is really a nice piece and bolted in easily. Thank God something went as it should!
Fuel system almost completed. Have one more line to make than install tank for last time. Also made bracket to mount corvette style filter/regulator and bracket to mount waterproof relay between rearend and fuel tank.
Mounted steering column and installed collaspible mid shaft.
Haven't figured out how to reroute my e-brake cable. its in the way of everything! Any suggestions?
Theres more to come.
ID:	589716   Click image for larger version
ID:	589720   Click image for larger version
ID:	589722   Click image for larger version
ID:	589726   Click image for larger version
ID:	589728   Click image for larger version
ID:	589730   Click image for larger version
ID:	589734   Click image for larger version
ID:	589736   Click image for larger version
red68chevL, Dan65ss and 1965_ss like this.
Jeff Evans
Jeff65SS is offline
post #66 of 76 (permalink) Old Mar 22nd, 19, 7:31 AM
Les
Started install of engine wire harness to help figure out location of ECM. Pretty sure I'm going to locate it on drivers side firewall tucked up where fender attaches to cowl.
That's where I put mine. It's pretty tight when the fenders (inner and outer) are installed. If I need to get to it, I'm pretty sure I will need to remove the inner fender panel.
Les
65 El Camino (LS2 Project)
83 El Camino (DD)
04 Corvette Convertible
14 Cruze
Skylarkul is offline
post #67 of 76 (permalink) Old Mar 22nd, 19, 7:47 AM
I placed my ECM / PCM on top of the glove box and underneath the dashboard top. I thought about putting it inside the glove box but that would have been a tight fit and then I'd have no glove box.
Sent from my SAMSUNG-SM-N900A using Tapatalk
B52bombardier1 is offline
post #68 of 76 (permalink) Old Mar 22nd, 19, 8:25 AM Thread Starter
I had seen you post and did the same with mine. looks like the Holley HP ECM is a bit smaller so it fit a little better.
Jeff Evans
Jeff65SS is offline
post #69 of 76 (permalink) Old Mar 22nd, 19, 8:34 AM Thread Starter
Was laying under the car looking at the e-brake cable routing. I think I can move the existing round stock support thats attached to the floor support and add another one on the next forward floor support. Place them so the stock cable length is still ok, that'll run the cable under the tailshaft of the trans.
I'd much rather be putting together bigger items, I hate having to back up and redo things that worked fine before. These are the things that kill the timeline of a project for me.
Sorry about the spelling error in my previous post, stupid auto correct changed heim to hemi.
Jeff Evans
Jeff65SS is offline
post #70 of 76 (permalink) Old Mar 22nd, 19, 9:28 AM Thread Starter
Here's a couple of pictures of the mods I had to do to the pedal box to make the hydraulic master fit. Modern Driveline uses a modified F-Body master.
Cut away material that interfered with master pushrod heim joint arc.
Clutch pedal stop.
ID:	589816   Click image for larger version
1965_ss likes this.
Jeff Evans
Jeff65SS is offline
post #71 of 76 (permalink) Old Mar 22nd, 19, 11:45 AM
Todd
Everything is looking great!!!
Jeff65SS likes this.
_____________________
Todd
1965_ss is offline
post #72 of 76 (permalink) Old Mar 22nd, 19, 1:43 PM
I still say, progress is progress...all those things need to get done, now or later. Great work!
Build thread-
Album -
Dan65ss is offline
post #73 of 76 (permalink) Old Mar 22nd, 19, 2:45 PM Thread Starter
Thanks!
But thinking I'm going to fall short of my goal.... driving in 6 weeks. Listing my house for sale mid May.
Jeff Evans
Jeff65SS is offline
post #74 of 76 (permalink) Old Mar 22nd, 19, 3:12 PM
Thanks!
Keep at it, when you are on a roll it's amazing how many things can get accomplished.
Build thread-
Album -
Dan65ss is offline
post #75 of 76 (permalink) Old Mar 29th, 19, 3:47 PM Thread Starter
Small update,
Got the parts I ordered for reroute of E-Brake cable. I'll post pics when I'm done.
Making up a few small brake lines right now, hope to wrap that up and bleed the brakes this weekend. Love flaring Nicopp! Have never used it before, very easy to work with.
While measuring for driveshaft I discovered I have a out of spec u-joint angle between the trans and driveshaft. Even raised the trans higher than the Holley provided spacers, best I can get is 4.5 degrees. Considering buying a driveshaft with the front CV joint. Expensive and not welcome at this given point.
Going to work on stuff that doesn't cost me a wad of cash for a couple of weeks. tired of spending money. LS swap ISN'T CHEAP!
Dan65ss likes this.
Jeff Evans
Jeff65SS is offline
