My 65 LS Swap Project - Page 2 - Chevelle Tech
Pro Touring Todays performance with classic style
 29Likes
post #16 of 76 (permalink) Old Mar 14th, 17, 8:37 AM Thread Starter
Re: My 65 LS Swap Project
Dan, I got their house brand clutch. Maybe its a repackaged name brand, not sure. 11" Kevlar/Kevlar good for +500 HP and some track use.
Jeff Evans
65 Chevelle, LS3/T56 transplant in progress
67 Chevelle, ZZ502, AFR 305, Straub Solid Roller, 400 Turbo, Moser Rear 3.42 gear
Jeff65SS is offline
post #17 of 76 (permalink) Old Mar 14th, 17, 2:10 PM
Nice. Good to get it all in one package. I was going to go with Bowler for that same type of thing, but ended up getting an engine/trans package deal, so went that route.
Build thread-
Album -
Dan65ss is offline
post #18 of 76 (permalink) Old May 18th, 17, 10:54 PM Thread Starter
Made some progress but not as much as I had hoped for. Fab work took me longer than I planned, turned out good but guess I'm just slow. Don't do it enough to be really fast at it!
Tunnel welded in, small amount of body filler on transition between firewall and tunnel/toe board. My firewall had already been smoothed and painted so instead of going through all that again I decided to paint the areas I worked on with a black rattle can and spray undercoating. Taped off the area I wanted to undercoat. Turned out pretty good. The rattle can undercoating has a nice texture and hides the fab sins pretty nicely. Not a show car, more of a driver. I also reundercoated the majority of the floorpan while I was at it.
Moving onto sound deadener/insulation for the floor, firewall and doors. Found a product on Amazon that looks and applys just like Dynamat. Its by a company Noico. Bought some of the 80 mil and 50 mil product.
Purchased my Vintage Air and Tanks Inc EFI tank/pump last week at Yogis here in Iowa. They gave me a pretty healthy discount too! And yes the EFI tank is the new sump version so should be able to drive it hard and not have any starvation issues.
Jeff Evans
Jeff65SS is offline
post #19 of 76 (permalink) Old May 19th, 17, 1:22 PM
YES, progress! I like how that undercoating came out on the firewall.
Build thread-
Album -
Dan65ss is offline
post #20 of 76 (permalink) Old May 22nd, 17, 1:05 PM Thread Starter
Thanks! Don't think it will hardly be noticeable.
Jeff Evans
Jeff65SS is offline
post #21 of 76 (permalink) Old May 22nd, 17, 7:18 PM
Les
Looking good Jeff.
I'm using AAW in my 65. The quality is good and it's very complete. The only down-side I found is that many of the wires are longer than needed, especially under dash. I have Vintage Air ducts running under the dash so, there's not a lot of extra room and, I ended up trimming a lot of the extra length out of thee wires. This made it necessary to re-work many of the pre-installed terminal ends.
It was a lot more work than I anticipated but, I'm good with the end results.
Les
65 El Camino (LS2 Project)
83 El Camino (DD)
04 Corvette Convertible
14 Cruze
Skylarkul is offline
post #22 of 76 (permalink) Old May 23rd, 17, 1:59 PM Thread Starter
Was hoping to avoid alot of cutting and making up end connections.......... Wanted more plug and play.
Oh, its just time right? We all have plenty of that
Jeff Evans
Jeff65SS is offline
post #23 of 76 (permalink) Old Jul 1st, 17, 8:46 AM
Keith
Another 65 build to follow!
I drive...a 65
Blitz is offline
post #24 of 76 (permalink) Old Mar 18th, 18, 10:46 PM Thread Starter
Finally back to this project and making some progress.....
Got all the interior insulated with NOICO peel and stick. Floor and firewall have the 80 mil while the top and doors have the 50 mil.
ID:	535105   Click image for larger version
ID:	535113   Click image for larger version
Schwany likes this.
Jeff Evans
Jeff65SS is offline
post #25 of 76 (permalink) Old Mar 18th, 18, 11:00 PM Thread Starter
Installed new switches and Dakota Digital gauge cluster. Added Vintage Air vent above radio, kind of like an OE location.
Jeff Evans
Jeff65SS is offline
post #26 of 76 (permalink) Old Mar 18th, 18, 11:34 PM Thread Starter
Trial fitted the Vintage Air. Waiting for painter to spray my DSE heater delete panel so I can assembly the firewall stuff. Install defrost duct, cut dash for OE A/C vents (thanks Dave Bates!). Defroster duct fit like a saddle on a sow so I had to silicone around the perimeter.
Also started on wiring but discovered I need a better crimper for installing the AAW terminals.... hurry up and wait!
ID:	535129   Click image for larger version
ID:	535137   Click image for larger version
Jeff Evans
Jeff65SS is offline
post #27 of 76 (permalink) Old Mar 19th, 18, 10:07 AM
Looks good Jeff and you're welcome. Did you have any difficulty removing the OEM defrost duct? I wanted to use one of my spot weld cutters but don't want to chance cutting too much. Keep up the great work and update us with you're progress.
USAF Retired (1968-1988)
David Bates is offline
post #28 of 76 (permalink) Old Mar 19th, 18, 10:47 AM Thread Starter
I did, I used a die grinder to cut away most of the duct metal and spot weld. Then used a chisel to pop it off. There was one place where there was a second poorly done spot weld about 1/4" away from the one i could see well. It ended up tearing a tiny chunk out of the cowl parent metal that I'll have to fix now. My cowl was nicely painted so I was real nervous about messing it up.... and I did. I have an air chisel and thought maybe I should have tried it instead.
Jeff Evans
Jeff65SS is offline
post #29 of 76 (permalink) Old Mar 19th, 18, 6:47 PM
Michael
How did you wire up the gauges? Did you use the CAN Bus option or just the little control box it comes with?
Paraman1 is offline
post #30 of 76 (permalink) Old Mar 20th, 18, 8:15 AM Thread Starter
I'm going to purchase the new Dakota Digital CAN bus device as it will deliver nearly everything needed from the Holley HP ECU..... I think. I still need to do a little research but that's what I've gathered so far from Dakota Digital.
Jeff Evans
Jeff65SS is offline
