New (to me) 72 El Camino Project - Chevelle Tech
Pro Touring Todays performance with classic style
 6Likes
post #1 of 31 (permalink) Old Jan 20th, 16, 11:31 AM Thread Starter
Wayne
Sold my 67 Chevelle a couple weeks ago so I looked around and found what I hope is a nice little 72 El Camino body. The nose has been swapped (doesn't look damaged underneath so it may have been removed to go onto someone's Chevelle) and no motor & trans, but other than that it's a really nice little car. I have had 8 Chevelle's over the years and no El Camino's so it's high time I did something about that. I had already purchased a 2002 LS-1 with a T56 6 speed transmission. It was slated to go into a 63 GMC pickup build I have started, but once I found this El Camino I kinda shifted gears (pardon the pun) and will now put this package together to make a Pro-Touring, Autocrossing, Daily Driver so I can have fun while I take my time on the 63 build.
Anyhow, only rust I have found is in the back panel below the rear glass. Might have a bit or two more but it was a Tucson AZ car it's whole life before it was brought up here to Phoenix.
Only have a couple pics but here is what I have.
Name:	El Camion 1.jpg
ID:	326025   Click image for larger version
Name:	El Camino 2.jpg
ID:	326033   Click image for larger version
Name:	El Camino 3.jpg
Brian Hoss likes this.
Later,
Wayne
cooperhw is offline
post #2 of 31 (permalink) Old Jan 20th, 16, 11:58 AM
Re: New (to me) 72 El Camino Project
71/72 Elcamino fenders will not work on a 71/72 Chevelle. The Elcamino has different body lines than the Chevelle has. The fender extentions are also different from Chevelle. The hood is interchangeable though. Nice project.
RealRed70 is online now
post #3 of 31 (permalink) Old Jan 20th, 16, 1:36 PM
JOHN
Good to see you here with an Elky .
FLASHED is offline
post #4 of 31 (permalink) Old Jan 20th, 16, 4:55 PM Thread Starter
Wayne
Hey Flashed. Thanks. I will try to not drag azz on this one so bad.
Later,
Wayne
cooperhw is offline
post #5 of 31 (permalink) Old Jan 20th, 16, 4:57 PM Thread Starter
Wayne
Thanks for the info. Like I said in original posting, I have had a bunch of Chevelle's but this is my first El Camino. Looking forward to a cool daily driver with an LS motor and a 6 speed.
Later,
Wayne
cooperhw is offline
post #6 of 31 (permalink) Old Jan 20th, 16, 9:55 PM
JOHN
Sounds fun ,Im in .
FLASHED is offline
post #7 of 31 (permalink) Old Jan 21st, 16, 10:30 AM
Ryan
Sounds and looks like a good puzzle piece to start. Good luck with the build. Cant wait to see some progress!
RideTech_Ryan is offline
post #8 of 31 (permalink) Old Jan 22nd, 16, 4:49 PM
Nice project!
_________
65 'ChevHell' Build Thread ~>
Diabolical is offline
post #9 of 31 (permalink) Old Mar 10th, 16, 12:42 PM Thread Starter
Wayne
Yeah, they all start with a chunk of iron and a vision. I have now got the motor/trans in and all the rot (all I know of now) out. Time to start moving forward. Soon as I get the heater core and fan blower swapped out tomorrow.
Originally Posted by Diabolical View Post
Nice project!
Thanks. I also think it's going to be nice.
ID:	339474   Click image for larger version
Later,
Wayne
cooperhw is offline
post #10 of 31 (permalink) Old Mar 10th, 16, 12:45 PM Thread Starter
Wayne
Sorry, a couple more.
ID:	339490   Click image for larger version
ID:	339498   Click image for larger version
ID:	339506   Click image for larger version
Later,
Wayne
cooperhw is offline
post #11 of 31 (permalink) Old Mar 10th, 16, 1:46 PM
JOHN
Was yours an A/C car ? Just wondering how bad the heater core will be on mine . I think I may just bypass mine again for now.
FLASHED is offline
post #12 of 31 (permalink) Old Mar 10th, 16, 1:52 PM Thread Starter
Wayne
Yes mine is an AC car which I will be hooking up immediately. I have the front clip off right now so it's never gonna be easier for me. Gonna pull the dash pad, dash, and heater core tomorrow. Want to put in a new heater core and fan blower motor before I start putting in the new gauges. Then I will start putting it back together. Hate when I have to backtrack later.
Even though this will be kinda down and dirty daily driver I want heat and AC upon start up.
cooperhw is offline
post #13 of 31 (permalink) Old May 26th, 16, 12:14 PM Thread Starter
Wayne
Been a busy last 2.5 months. Finished up the welding after cutting out all the rot. Replaced one front fender and a door skin on the drivers side. It had been hit hard enough on that side to bend the door hinge. Took a lot of work to finally get the doors and fenders to line up pretty close then finessed them from there.
Gaps looked great when I blew it back apart for paint. In the middle of epoxy, polyester, polyester right now trying to get it straight. Hopefully I will have it in color by the 4th of July.
ID:	362593   Click image for larger version
ID:	362601   Click image for larger version
ID:	362609   Click image for larger version
Later,
Wayne
cooperhw is offline
post #14 of 31 (permalink) Old May 26th, 16, 12:19 PM Thread Starter
Wayne
Couple more pics,
ID:	362625   Click image for larger version
ID:	362633   Click image for larger version
ID:	362641   Click image for larger version
Later,
Wayne
cooperhw is offline
post #15 of 31 (permalink) Old May 26th, 16, 12:48 PM
Very nice progress!
_________
This Thread is more than 1353 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
