LT1 Accessory Brackets - Chevelle Tech
Pro Touring Todays performance with classic style
post #1 of 11 (permalink) Old Nov 28th, 08, 8:16 PM Thread Starter
JDF
I have a 97 SS Camaro LT1 going in a 70 Chevelle. Does anyone have bracket dimensions to re-locate LT1 accessories? There is a nice kit from S&P for all accessories for $$$, and Bowers Race and Rod Shop has an AC delete/relocate pulley bracketing for slightly less $$$, but I'm not seeing any posts with functional dimensions for us less fortunate that have to fab at home. I'll start mocking something up soon when I get the engine back in, but in the meantime if you're out there with the info already let me know!
JDF is offline
post #2 of 11 (permalink) Old Nov 28th, 08, 11:43 PM
Thomas
Re: LT1 Accessory Brackets
I put a 94 LT1 in a 67 and used the LT1 brackets and all accessories including the AC compressor.
Carolina Chevelle Association
TC # 688
ACES 2759
PeachState Chevelles
66 malibu wagon, 327, AC, pw.
67 chevelle 300 deluxe post, LT1-4L60E, 3:36-10 bolt posi,AC,tilt,pw,pl, Autometer gauges,custom dash
67 300 Deluxe, factory AC, project
"I think we have more machinery of government than is necessary,
too many parasites living on the labor of the industrious."
--Thomas Jefferson, letter to William Ludlow, 1824
elcamino66 is offline
post #3 of 11 (permalink) Old Nov 29th, 08, 12:25 AM
Derrick
have you tried fitting everything to see if anything actually needs to get moved? i think the F body brackets and accessories are the same as the B body parts, and i know there are a couple of guys that have put B body LT1's in their Chevelles without screwing around with anything.
-Hank Hill
novaderrik is offline
post #4 of 11 (permalink) Old Nov 29th, 08, 2:04 AM Thread Starter
JDF
Yeah, I'm going to try it. I'll put the engine back in tonight and put on the accessories. Who knows, if it works, there may be room for a supercharger on the drivers side later on!
JDF is offline
post #5 of 11 (permalink) Old Nov 29th, 08, 11:35 AM
Big Al
F-body stuff worked fine on my 72 with the AC delete pulley. Pretty sure the Y-body stuff will work with the AC without mods.
1968 Impala Turbo 6.0 798 RWHP
72' 5 speed LY6 Malibu-Sold
SleeperBBC is offline
post #6 of 11 (permalink) Old Nov 29th, 08, 1:41 PM
"The Stig"
It will fit with stock brackets.
A/C compressor is tight, but will work if you modify the rear compressor bracket... if you delete the A/C (pulley for 1LE package Camaro) you won't have any problems at all.
Derek Kiefer, member of Minnesota's
Derek69SS is online now
post #7 of 11 (permalink) Old Nov 30th, 08, 7:08 PM
Pypes Exhaust
Let me know if you need any of the brackets. I have a wrecked 97 SS at home.
PYPES EXHAUST SPONSOR
BrandonT
My ride
1969 Chevelle 325 HORSE "SS 396" / 4 SPEED
NUMBERS MATCHING / ASZURE TOURQUISE
396-325hp is offline
post #8 of 11 (permalink) Old Dec 2nd, 08, 12:44 AM Thread Starter
JDF
I'm short the power steering system (pump, lines, reservoir), idle tension arm and am not sure about the working condition of the AC parts. I don't have a radiator yet also. I started looking on line today.
As for the engine I'm running an LT4 Hotcam and 30 Lb injectors and it's complete. I don't have any engine top cover plates, EGR block-off plates or throttle cable.
Transmission (T56) I need the hydraulic clutch assembly and I'm fabricating the adapter bracket this week I think.
Let me know what you've got and want for it. Thanks!
Last edited by JDF; Dec 2nd, 08 at 1:53 AM. Reason: didn't need to post my e-mail address
JDF is offline
post #9 of 11 (permalink) Old Dec 2nd, 08, 9:44 AM
Pypes Exhaust
I'll pull the engine out and see what I have and get some pics for you. Do you want to PM me your email address or do you want me to send pics to your PM?
Brandon
BrandonT
My ride
post #10 of 11 (permalink) Old Dec 5th, 08, 9:41 PM Thread Starter
JDF
I scored the A/C system from a friend of mine yesterday so at least that's out of the way. Thanks Jerry! I'm still looking for the power steering stuff but will go ahead and install the engine this weekend and start on the accessory bracket and weld in the O2 bungs.
Good times!
JDF is offline
post #11 of 11 (permalink) Old Dec 8th, 08, 9:26 PM
Derek
If you can't find all the power steering tuff you need, I have an extra power steering pump laying around. I think it might have a hose or two on it as well. I was going to use it, but I bought a donor car so I have this one still.
frochevy is offline
This Thread is more than 4001 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
