Mali2ude going together for Power Tour 08 - Page 11 - Chevelle Tech
Pro Touring Todays performance with classic style
post #151 of 347 (permalink) Old Apr 24th, 08, 10:34 PM
Re: Mali2ude going together for Power Tour 08
Can you shed some light on the lip that is pressed into the ends of the tubing? I have witnessed how boost can seperate some couplings and that added lip will certainly help. Was it done post-welding from regular tube, or did you buy tubing that already had the lip in one (or both) ends?
The titanium is going to look great with the grays and blacks in the engine bay. Hopefully it isn't too light of a shade.
Thanks again for sharing the pics with us.
member number 684
71' coupe project:
goal: 150+MPH, 9s driven to and from track, 275 front tire, 315 rear tire, 1000+HP
Build: 540cid, twin turbo, 4L80e, ...wait for it...
BB_Mike is offline
post #152 of 347 (permalink) Old Apr 24th, 08, 10:37 PM Thread Starter
I have a bead roller tool to put a bead on the ends of tubing. Really cool and pretty much a necessity with boost, as you said.
Jody
Jody
camcojb is offline
post #153 of 347 (permalink) Old Apr 25th, 08, 2:10 PM
Alan
I'm just going to sell my Chevelle. Where's a white towel smilie at when you need it??
Some awesome work there Jody. Thanks for sharing the Mali2ude buildup with us.
Alan is offline
post #154 of 347 (permalink) Old Apr 26th, 08, 11:31 PM Thread Starter
thanks!
Jody
camcojb is offline
post #155 of 347 (permalink) Old Apr 26th, 08, 11:32 PM Thread Starter
next, I sent the intake plumbing to be coated with titanium header coating. The color matches well with the car, but it sure scratches and scuffs easily. Might have to re-think that one later on. Big thanks to Steed at Perfect It powder coating in Rancho Cordova for helping me out, getting this back to me in one day.
Jody
camcojb is offline
post #156 of 347 (permalink) Old Apr 26th, 08, 11:33 PM Thread Starter
added some new turbo heatshield bags. The other ones I had on there didn't fit well, these are much nicer.
added my heater hoses
Jody
camcojb is offline
post #157 of 347 (permalink) Old Apr 26th, 08, 11:33 PM Thread Starter
had my headlight frames powdercoated. Changed the halogen bulbs for true HID's, with HID low and high beam on the one bulb. I don't think I'll even plug in the normal inside high beam as it won't match and the two outside lights will be plenty.
a quick pic of the air inlet tube. Has a little bracket that supports the end, from that small button-head allen screw just above the pipe. Filters are on order. Basically copied what Mark had in the car, seemed to work well.
Jody
Jody
camcojb is offline
post #158 of 347 (permalink) Old Apr 27th, 08, 12:16 AM
Andrew
Moving right along Jody! Where did you get the HID lights?
Andrew
Instagram @projectgattago
Please get in touch for Holley EFI tuning services.
andrewb70 is offline
post #159 of 347 (permalink) Old Apr 27th, 08, 12:24 AM Thread Starter
Andrew
had a set in my shop, but they were HID on low beam only. Had one bad bulb so I found this guy on Ebay for low/high HID's that worked with my ballasts. He also has complete kits with bulbs, ballast, wiring harness.
http://cgi.ebay.com/ebaymotors/ws/eB...m=360041698950
Jody
camcojb is offline
post #160 of 347 (permalink) Old Apr 27th, 08, 6:14 PM Thread Starter
Hooked up the throttle this morning. I own a tig, but can't weld with it................... so I bought a Lokar cable mount and built a bracket to attach it to the fuel rail support. Turned out nice. The cable has a bit of an angle to it, but that's how the Lokar mount is built, and was the only way it was going to fit.
Jody
Jody
camcojb is offline
post #161 of 347 (permalink) Old Apr 27th, 08, 11:26 PM
Pretty.
Is it setup to handle E85 gas? What size injectors did you go with?
With such a clean fire wall, where is your fuel psi regulator?
With all of this effrot, you should start to advertise to get some magazine or TV recognition during the power tour!
I'm looking forward to the finished interior photos.
member number 684
71' coupe project:
BB_Mike is offline
post #162 of 347 (permalink) Old Apr 27th, 08, 11:31 PM
Troy
Jody is a bad influence.... very bad.
As of this weekend I have a buyer for my Procharger committed, I'm already looking at compressor maps for GT-series turbos, and I'm getting prices on material to build my own manifolds.
Jody did something like this to me about 5 years ago... I went up to look at his Procharged '69 Camaro on a Saturday and ordered my Procharger on the following week.
Looks great. Let me know when you get ready to fire it, I want to come back up and check things out (and go for a ride... LOL)
1969 Chevelle
Old setup: Procharged/intercooled/EFI 353 SBC, TKO, ATS/SPC/Global West suspension, C6 brakes & hydroboost.
In progress: TT LS2, T56 Magnum, watts link, Wilwood Aero6/4 brakes, vaporworx, floater 9" rear, etc.
Gokou is offline
post #163 of 347 (permalink) Old Apr 28th, 08, 1:42 AM
...I went up to look at his Procharged '69 Camaro on a Saturday and ordered my Procharger on the following week.
I had almost the same experience when seeing Jody's yellow Camaro, except I went home, looked at my bank statement, and then looked in the phonebook to try and guess which divorce attoney my wife would be getting...
Of course, Troy's car brings out the same feeling's in me (envy, inadequacy and delusions of having some of those parts on my car)
"I am happy with my N/A "project" car... I am happy with my N/A "project" car... I am...
TC #1366
Sold
Sold
1966_L78 is online now
post #164 of 347 (permalink) Old Apr 28th, 08, 11:01 AM Thread Starter
Pretty.
this is a pump gas build with 75# injectors. I may have to go larger after seeing the duty cycle, but I had these at my shop so I'm using them initially. As far as I know there isn't an E85 station anywhere near where I live. If there was I'd be tempted for sure.
The regulator is back at the tank along with the pump. Thanks!
Jody
Jody
camcojb is offline
post #165 of 347 (permalink) Old Apr 28th, 08, 6:49 PM
Hey jody I know it might have been there already but do you know were that firewall Heater hose plat came from
DEMONIC OBSIDIAN
1965 Chevelle LS2 project.
Rantheman is offline
This Thread is more than 4233 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
