Crashed Chevelle - Chevelle Tech
Pro Touring Todays performance with classic style
 2Likes
post #1 of 20 (permalink) Old Jan 16th, 20, 9:11 PM Thread Starter
bryce
Crashed Chevelle
Hey guys- does anyone remember seeing and reading about the crushed Chevelle? It was featured at SEMA I believe this past year - it was a gray pro touring 1972 that apparently was on the way to the crusher and got saved. The guys plus their sponsors did a fantastic build on and I am trying to get info on it but unfortunately this is about all the social media I do is here. The question maybe someone may have an answer to is: The car is running 18 x 11“ wheels with 315 on the back and running 18 x 10“ wheels with a 275 tire and the wheels are American racing. The guys in all the information I have found states they did chassis/frame modifications to accommodate those size tires and wheels. I’m trying to figure out how they were able to manage those sizes without any modifications. Does anybody have any theories or ideas?
phat1972 is offline
post #2 of 20 (permalink) Old Jan 16th, 20, 9:27 PM
re: Crashed Chevelle
This one?
https://www.hotrod.com/articles/1908...track-crusher/
71350SS likes this.
post #3 of 20 (permalink) Old Jan 16th, 20, 9:30 PM Thread Starter
bryce
Yep- that’s the one.
Guess I should have labeled it better as the crashed Chevelle
phat1972 is offline
post #4 of 20 (permalink) Old Jan 16th, 20, 9:40 PM
Google has gotten so now days if you google gray 1972 Chevelle it will bring up page after page of vehicles of all different makes, years, and colors.
post #5 of 20 (permalink) Old Jan 16th, 20, 9:51 PM Thread Starter
bryce
Very true. I should have been more specific.
I’m looking at doing the same set up but didn’t want to mini tub just because the price doesn’t make financial sense considering you only get maybe an inch and half so when I seen this- I was def interested- just couldn’t figure out how it was done.
phat1972 is offline
post #6 of 20 (permalink) Old Jan 16th, 20, 10:31 PM
Justin
I think it’s the crashed Chevelle rather than the crushed.
JF74chevelle is offline
post #7 of 20 (permalink) Old Jan 16th, 20, 11:59 PM
Re: Crashed Chevelle
Changed the thread title to Crashed.
post #8 of 20 (permalink) Old Jan 17th, 20, 6:37 AM
If you donít want to do mods then you only have what room is available for the tire. Then once you get the tire size that will fit itís all about the backspace.
I had a 70 and I didnít think there was room for that much tire but maybe. Throw a tape measure in there and see what you got to work with.
67
70 (SOLD)
Alwhite00 is offline
post #9 of 20 (permalink) Old Jan 17th, 20, 2:28 PM Thread Starter
bryce
Well I have done that much ; and I realize not all Chevelles are the same , but a 315 on the back and a 275 on the front is freakin huge even for a stock Chevelle. I’m just trying to figure how it’s even possible and if anyone has had any experience with even close to that size with out mods
Originally Posted by Alwhite00 View Post
If you don’t want to do mods then you only have what room is available for the tire. Then once you get the tire size that will fit it’s all about the backspace.
I had a 70 and I didn’t think there was room for that much tire but maybe. Throw a tape measure in there and see what you got to work with.
phat1972 is offline
post #10 of 20 (permalink) Old Jan 17th, 20, 5:41 PM
Originally Posted by phat1972 View Post
Well I have done that much ; and I realize not all Chevelles are the same , but a 315 on the back and a 275 on the front is freakin huge even for a stock Chevelle. Iím just trying to figure how itís even possible and if anyone has had any experience with even close to that size with out mods
How much room is in the back?
67
70 (SOLD)
post #11 of 20 (permalink) Old Jan 17th, 20, 7:31 PM
"The Stig"
I have 275/35/18 Front and 315/30/18 Rear
9.5" front with 5.75" backspace
11" rear with 6.25" backspace
Front has a corrected camber curve using Speedtech AFX spindles and aligned with 2į of negative camber.
Rear has trimmed lips and a watts link to keep the axle centered.
71350SS likes this.
Derek Kiefer, member of Minnesota's
Derek69SS is offline
post #12 of 20 (permalink) Old Jan 17th, 20, 8:15 PM
315 should fit under your 70 with no problem. Bet its a better fit than a 295/50/15
cuisinartvette is offline
post #13 of 20 (permalink) Old Jan 17th, 20, 9:28 PM Thread Starter
bryce
Thanks for that post- that is def helpful . I am running At the current time 20x10 with 275 which was on the car when I bought it. I have an inch and a half extra on both sides on the back and that is with rear end completely centered.
phat1972 is offline
post #14 of 20 (permalink) Old Jan 17th, 20, 10:23 PM Thread Starter
bryce
With the 2 degrees negative camber; do you have any excessive tire wear? Do you have it set that way to accommodate a big tire or for road course racing?
phat1972 is offline
post #15 of 20 (permalink) Old Jan 17th, 20, 11:14 PM
"The Stig"
Not really, but I do a mix of street miles and autocross.
Tires get lose grip from heat cycling and need replacing before they wear out anyway.
