Chevelle 2.0 - Page 7 - Chevelle Tech
Pro Touring Todays performance with classic style
 33Likes
post #91 of 116 (permalink) Old Jun 14th, 19, 6:31 PM Thread Starter
Herb
Re: Chevelle 2.0
Originally Posted by 1965_ss View Post
Yes!!!!!!!!!!!!!!!!!!!
How do you mount the body to the frame now?
When I put the body back on, I'll attach it with four of the body mounts along with bolting the core support in place. Then the rockers will be welded to the frame along with some areas in the trunk.
1965_ss likes this.
Herb
1966 El Camino LS408/T56Magnum
1966 Chevelle 509/T56Magnum
1963 C10 454/4L80
Yelcamino is offline
post #92 of 116 (permalink) Old Jun 14th, 19, 11:24 PM
Tyler
Re: Chevelle 2.0
Unreal Herb! Can't wait to see it finished!
66 Malibu. STILL... Working toward participation in Optima events! Rebuild in progress.
66promalibu is offline
post #93 of 116 (permalink) Old Jun 15th, 19, 11:55 AM
Dennis
Re: Chevelle 2.0
Subscribed.
Yelcamino likes this.
67_LS1 is offline
post #94 of 116 (permalink) Old Jun 16th, 19, 5:04 PM Thread Starter
Herb
Re: Chevelle 2.0
Thanks!
Herb
1963 C10 454/4L80
post #95 of 116 (permalink) Old Jun 16th, 19, 5:15 PM
Nick
Re: Chevelle 2.0
Hey Herb, good job buddy...
Nick
Here's a link to my 2014 Camaro SS donor to 70 Malibu restomod project:
pcguy is offline
post #96 of 116 (permalink) Old Jun 16th, 19, 5:51 PM Thread Starter
Herb
Re: Chevelle 2.0
The chassis is once again upright. I still need to add some more tubes but it's steadily getting closer to paint.
20190615_183816 by Yelcamino, on Flickr
Here are some close ups of my TIG work. With every joint, the quality improves.
20190615_163107 by Yelcamino, on Flickr
20190611_150955[1] by Yelcamino, on Flickr
20190613_184730[1] by Yelcamino, on Flickr
20190614_174236 by Yelcamino, on Flickr
And this is my Fupa 12 that works like a charm!
20190615_132508 by Yelcamino, on Flickr
-SS454-, Dan65ss and 1965_ss like this.
Herb
1963 C10 454/4L80
post #97 of 116 (permalink) Old Jun 17th, 19, 8:42 PM Thread Starter
Herb
Re: Chevelle 2.0
Nick
Thanks Nick!
Herb
1963 C10 454/4L80
post #98 of 116 (permalink) Old Jun 30th, 19, 7:56 PM
Clint
Re: Chevelle 2.0
Herb, you planning to run roadrace slicks on that car?
Clint Hooper
Sold
Clint44 is offline
post #99 of 116 (permalink) Old Jul 1st, 19, 10:35 PM Thread Starter
Herb
Re: Chevelle 2.0
Maybe one day.
Herb
1963 C10 454/4L80
post #100 of 116 (permalink) Old Jul 15th, 19, 4:12 PM Thread Starter
Herb
Re: Chevelle 2.0
Some more quick updates...
Before I painted everything, I made templates for the belly pans.
B006 by Yelcamino, on Flickr
Then I got busy with some VHT chassis black.
B007 by Yelcamino, on Flickr
B008 by Yelcamino, on Flickr
Then I transferred the templates to aluminum and drilled all the holes (around 250). Before I install the pans to stay, I'll countersink the holes so the screws will be flush. I also got started on the Heat Shield Products heat reflective fabric. I still need to finish the dog house and then some, possibly all, of the firewall after the body is on to stay.
B005 by Yelcamino, on Flickr
Then I got to do some fun stuff - installing the front suspension! :yeah:
B003 by Yelcamino, on Flickr
B004 by Yelcamino, on Flickr
B002 by Yelcamino, on Flickr
B001 by Yelcamino, on Flickr
Jeff65SS and -SS454- like this.
Herb
1963 C10 454/4L80
post #101 of 116 (permalink) Old Jul 15th, 19, 4:15 PM
Re: Chevelle 2.0
So much cool happening here it is hard to take it all in. Love it!
Build thread-
Album -
Dan65ss is offline
post #102 of 116 (permalink) Old Jul 15th, 19, 4:29 PM Thread Starter
Herb
Re: Chevelle 2.0
Thanks!
Herb
1963 C10 454/4L80
post #103 of 116 (permalink) Old Jul 20th, 19, 8:44 AM Thread Starter
Herb
Re: Chevelle 2.0
I installed the rear suspension and got it on the scales. Total weight is 1365 with only 43.52% on the front, not too bad.
20190719_174817 by Yelcamino, on Flickr
20190719_173002 by Yelcamino, on Flickr
As I assembled everything, I weighed each part so I could see where the weight was coming from and also to help when it comes time to balance left/right/front/back. This is what I have so far:
Steering rack - 15lbs
Driver side upper/lower arms, spindle, C7 hub - 31lbs
Passenger side upper/lower arms, spindle, C7 hub - 31lbs
Coilovers (11lbs ea) - 22lbs
Rotors (20lbs ea) - 40lbs
Calipers & pads (8lbs ea) -16lbs
Wheels & tires (48lbs ea) - 96lbs
Front Suspension total - 251lbs
3 links & hardware - 15lbs
Watts links - 9lbs
Rear end housing assembly (no oil or axles) - 220lbs
Rear axles - 20lbs
Calipers & pads (8lbs ea) - 16lbs
Wheels & tires (51lbs ea) - 102lbs
Rear Suspension total - 404lbs
Chassis & cage - 710lbs
Total weight - 1365lbs
If you remember, after I first test fit the body to the chassis, I scaled it and it was 1875 lbs. None of the cage components were in it at the time but all the suspension parts were.
It will be interesting to see how much the body will add.
Herb
1963 C10 454/4L80
post #104 of 116 (permalink) Old Jul 20th, 19, 9:49 AM
Re: Chevelle 2.0
WOW !!!! Awesome car !!!
72 Malibu Family Fun Car
Seven2bu is offline
post #105 of 116 (permalink) Old Jul 20th, 19, 11:09 PM Thread Starter
Herb
Re: Chevelle 2.0
Thanks!
Seven2bu likes this.
Herb
1963 C10 454/4L80
