Troy Built 66 Chevelle LS3/T56 - Page 8 - Chevelle Tech
Pro Touring Todays performance with classic style
 111Likes
post #106 of 148 (permalink) Old May 20th, 19, 8:49 AM
Todd
Re: Troy Built 66 Chevelle LS3/T56
Originally Posted by senna View Post
Wrong, It is right side up. I inverted the x member mount to achieve the height I needed.
Oh ok. Cause I welded the X member mounts the other way per their instructions. I have been wondering where the trans mount pad sits in relation to the bottom of the frame where the X member used to bolt to the frame. Is the mount pad flush with the bottom of the frame or about the middle?
91c1500sleeper is offline
post #107 of 148 (permalink) Old May 20th, 19, 11:47 AM Thread Starter
Troy
The mount for the x member is 1.5" above the bottom of the frame rail.
If you welded your's per the instructions then you are probably 3/4" bellow the original location. If you use the weld on "L" bracket for the factory x member it shouldn't be an issue.
91c1500sleeper likes this.
66 CHEVELLE
senna is offline
post #108 of 148 (permalink) Old May 22nd, 19, 8:49 PM Thread Starter
Troy
I sent the frame to the frame shop, as suspected the right frame horn was one inch higher than it should be. Hopefully this cures the small issue I had with tie rod clearance on the bottom of the oil pan on that side.
I also got the rear diff back freshly built with 3:73 gears and posi traction.
Jeff65SS and Dan65ss like this.
66 CHEVELLE
senna is offline
post #109 of 148 (permalink) Old Aug 22nd, 19, 1:47 AM Thread Starter
Troy
It's been a while since I've posted any updates. Been a lot waiting for parts to do the coil over conversion. I have all the rear parts and pretty much have everythin done except some welding.
Schwany likes this.
66 CHEVELLE
senna is offline
post #110 of 148 (permalink) Old Aug 22nd, 19, 11:52 AM
Looking nice! What dimension coilover did you go with? How long are they? What is the spring rating?
Build thread-
Album -
Dan65ss is offline
post #111 of 148 (permalink) Old Aug 22nd, 19, 12:09 PM Thread Starter
Troy
Thank's Dan
The shocks are 14.52" extended length and have 5.15" of travel. They use a 12" spring and were shipped with a 250# spring rate.
427L88 and Dan65ss like this.
66 CHEVELLE
senna is offline
post #112 of 148 (permalink) Old Aug 22nd, 19, 2:02 PM
Thank's Dan
Thank you! Good to have this information in a thread for everyone to see.
senna likes this.
Build thread-
Album -
Dan65ss is offline
post #113 of 148 (permalink) Old Aug 23rd, 19, 12:16 AM
Tyler
Looking good!
senna likes this.
66promalibu is offline
post #114 of 148 (permalink) Old Aug 25th, 19, 9:14 PM Thread Starter
Troy
I got the coil over upper mount welded in and the back half boxed.
Just need the front coil overs to locate the front mounts.
Dan65ss and 66promalibu like this.
66 CHEVELLE
senna is offline
post #115 of 148 (permalink) Old Sep 30th, 19, 11:05 PM Thread Starter
Troy
Stopped by the body shop today. They are starting to make good progress.
Still waiting on the front coil overs, talked to them today and they said they should ship this week.
Dan65ss likes this.
66 CHEVELLE
senna is offline
post #116 of 148 (permalink) Old Oct 1st, 19, 8:14 AM
Exciting times.
senna likes this.
Build thread-
Album -
Dan65ss is offline
post #117 of 148 (permalink) Old Oct 5th, 19, 7:16 PM Thread Starter
Troy
Still waiting on the front coil overs, any day now.
So I decided to mock up the AFX tall spindles. Makes me feel like I'm accomplishing something.
pannetron likes this.
66 CHEVELLE
senna is offline
post #118 of 148 (permalink) Old Oct 5th, 19, 8:20 PM
J
Good stuff! You have a lot of nice hardware. It’s going to be one sweet ride! Are those the Speedtech upper coil over towers?
NorCal-SS is offline
post #119 of 148 (permalink) Old Oct 5th, 19, 8:30 PM Thread Starter
Troy
Originally Posted by NorCal-SS View Post
Good stuff! You have a lot of nice hardware. Its going to be one sweet ride! Are those the Speedtech upper coil over towers?
Yes on the Speedteck coil over mounts. Also the spindles are from Chassis Works.
66 CHEVELLE
senna is offline
post #120 of 148 (permalink) Old Oct 13th, 19, 9:47 PM
Todd
Looks great!
_____________________
Todd
1965_ss is offline
