Chevelle Tech - View Single Post - Dim Headlight
Thread: Dim Headlight
post #9 of (permalink) Old Feb 14th, 14, 11:19 PM
lg1969
Louis
Re: Dim Headlight
Do a continuity test with DVM, set it X1 ohm and check the black wire from each headlight socket to the ground lug. It should read zero ohm. If read "0", Then either have a poor ground or a loose connector.
Louis
Original owner
lg1969 is offline
