Chevelle Tech - View Single Post - 65 AM Radio connections
post #2 of (permalink) Old Dec 2nd, 13, 8:52 PM
Coppertop
Re: 65 AM Radio connections
-----edit---/---//-/
Disregard previous info...
Turn the radio around so the rear faces you. The 3 connections will be on your right and the antenna plug hole on the left
Now, as you are looking at the connectors left to right...
A B C
A=ground return for speaker
B= speaker +
C= 12 volt power input
Case of radio is ground connection for power.
Do not use a speaker rated at less than 8 ohms.
Coppertop is offline
