Chevelle Tech - View Single Post - Dakota Digital Wiring - Help Needed
post #1 of (permalink) Old Nov 27th, 13, 7:43 PM Thread Starter
man44a
Michael
I am converting my 1971 SS dash to the Dakota Digital SS VHX direct fit system. I have a few questions I'm hoping you can help with.
1. Constant Power - Can I use the clock wiring? Direct Connect?
2. ACC Power - What do you use for accessory power? Can I run a wire from the ACC on the fuse block?
3. Tail Light - This is to turn on the LED backlights at night. Can I use the gray wire from the printed circuit plug? If not, what do you use for this?
man44a is offline
