Chevelle Tech - View Single Post - Why my Tailight no work?!
post #7 of (permalink) Old Nov 27th, 13, 6:46 PM
CoolBlueGlow
Keith
Re: Why my Tailight no work?!
Darren, I believe he said he's talking about the tail lamps, not the brake lamps. tail lamps dont go through the brake lap switch.
Scott, I presume you've checked the bulbs themselves? The 1157 in our 67 brake/tail lamp assembly is a dual filament bulb...which means your brakes and turns can work fine and the tail lamp filament can be burned out.
I know you said the tail lamps "were working" but old bulbs can and do fail just from a little rough handling.
Double check the quality of the connection inside the tail lamp socket as well.
Just some things to check...
Keith
Owner: World's Fastest 66 Chevelle - really...it's really really fast since I put on that chrome differential cover
CoolBlueGlow is offline
