Chevelle Tech - View Single Post - Factory temp gauge and aftermarket at the same time.
post #4 of (permalink) Old Nov 27th, 13, 11:28 AM
Turbine
Re: Factory temp gauge and aftermarket at the same time.
Could you drill and tap the manifold at one of the rear water ports?
71 Chevelle
LM7 5.3l genIII 295hp / Th-350 / Quick Performance 9 inch housing, Ford 3.55:1 Traction - Lok, Moser Axles, Gm Disc / Drum brakes.
LS & 9 inch Swap complete!!!
255/45/17 front, 275/40/17 rear, SPC Springs, Stock front suspension geometry + Koni Ds and UMI rear arms. Planning SC&C Stage II+ front
Turbine is offline
