Chevelle Tech - View Single Post - xeon headlights
Thread: xeon headlights
post #2 of (permalink) Old Oct 15th, 13, 7:39 PM
Coppertop
Re: xeon headlights
Scott,
If they are truly direct replacements for the '6014's and the '6024's, the current shouldn't be an issue. I serious doubt they draw less. I couldn't find any specs on them. On my H5006 and H5001's I did my own regulated voltage tests. The drop in replacement Wagner Halogens drew approx. 1.5 amps more. Nothing to upset the apple cart unless your wiring and headlight switch questionable.
FYI, Rock Auto also sells these. You might even be able to get them locally. If you try them, post your results, I'm curious as I have always liked Wagner products.
Coppertop is offline
