Chevelle Tech - View Single Post - '69 Wiring Harness
post #3 of (permalink) Old Oct 10th, 13, 7:02 PM
HiFire
Re: '69 Wiring Harness
I rewired my 68 with a complete harness kit from AAW. I was a auto mechanic for 8 years in a previous life. I would definitely recommend their products. The only thing I needed to buy was a good set of crimpers. As long as you read all the instructions, separate every wire and determine where they go, and take a break when you get frustrated there should be no problems. I removed all the circuits from the harness that I wasn't going to use before I began the installation so they wouldn't get in the way. If you decide to take it on yourself, don't hesitate to ask for help. No matter what problem you run into I'm sure someone here has had the same problem and will be able to help you. Doing the work yourself will just make it easier to diagnose any problems you may run into in the future. Good luck.
HiFire is offline
