Play in steering wheel - Chevelle Tech
post #1 of 10 (permalink) Old Jun 1st, 16, 2:54 PM Thread Starter
Iím ignorant. Educate me. There is an allen (?) fitting on top of the PS box. Will that take some play out of the steering wheel, or should I leave it alone? Thanks
Notes is offline
post #2 of 10 (permalink) Old Jun 1st, 16, 2:58 PM
Randy
Re: Play in steering wheel
Check for looseness elsewhere, rag joint, center link, idler arm, tie rods, ball joints, control arm bushings. Adjusting the steering box isn't a good move. If it needs adjustment, it's worn out.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #3 of 10 (permalink) Old Jun 1st, 16, 4:12 PM
Bryan
I agree with Randy. Check the rag joint first, it is inexpensive and easy to rebuild it.
'66 SS Clone
Fast Burn 385hp Crate 350 (for now)
Muncie M20 & 3.42 Posi
UMI Stage 2 Suspension all around
bry66 is offline
post #4 of 10 (permalink) Old Jun 2nd, 16, 1:27 AM
leo
I agree with most of this thread, the rest of the steering components need to be checked first, you'll need a helper to check some of it. After checking it, have your helper wiggle the steering wheel back and forth,just taking out the play to see if indeed the play is in the box, if so, you might be able to adjust it out.
Here is the method I use, jack up the front end and place on jack stands, loosen the outer nut on the allen head screw about three threads, you'll probably have to hold the inner allen head screw while doing this, next, turn the allen head screw in 1/4 of a turn, then move the steering wheel thru it's arc, lock to lock and see if you feel any tightness as you move thru the center position, if you do, you are finished, hold the inner allen head screw and tighten the outer locknut, if not, try another 1/4 turn and repeat the above method, good luck! DO NOT OVERTIGHTEN the steering box. if you don't feel safe to try this, find an old school front end shop and get them to check your car suspension and steering for you.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #5 of 10 (permalink) Old Jun 2nd, 16, 10:03 AM
Stan
If you've checked everything else and isolated the play to the steering box, playing with the sector shaft adjustment may help a bit, but don't expect much improvement. Its not a "wow! that fixed it" kind of thing.
stanski is offline
post #6 of 10 (permalink) Old Jun 2nd, 16, 11:57 AM
Robert
Follow what Leo wrote and you should be fine. They make them adjustable for a reason so they can be adjusted over time as the boxes wear. Just make adj. is small increments. Here is a good video for Cougars that helped me with one of my cars, it could help some on your car but I don't know how much transfers over to Chevelles but I would think most of it would.
'67 Elky Global West suspension kit with coil over QA1's, 435hp Edy Crate,700R4, Currie +9 3:75, Disc brakes front and rear, Dakota Digital gauge package, 12 Circuit Painless wiring kit, Ididit tilt Colum, etc.
2012 HD Tri-Glide in Vivid Black.
1967 XR7 Cougar S code 390.
2016 Charger R/T in Purple.
rak1 is offline
post #7 of 10 (permalink) Old Jun 2nd, 16, 6:08 PM
Lang
Follow all the information provided above especially the small increments part. From personal experience, I watched a guy just wrench his down until the Steering Wheel "seemed" to have lost all the play. He starts his car up backs out of the driveway, takes off down the street and when attempting to turn around and come back, the steering box locked in a right hand turn mode. Well that was a pricey fix. Key Word here is "Small Increments".
langss is offline
post #8 of 10 (permalink) Old Jun 2nd, 16, 11:15 PM Thread Starter
Thanks to all for the replies. Much appreciated
Notes is offline
post #9 of 10 (permalink) Old Jun 4th, 16, 2:44 PM
Lew
Or you could first check everything else make sure it is OK and then buy a Saginaw 600 steering box from global west which is a direct bolt in and the steering will be much better. About $600 but makes a big difference. Steering is something you use all the time.
Lew540 is offline
post #10 of 10 (permalink) Old Jun 4th, 16, 3:27 PM
Sloppy Steering Syndrome - Problems & Solutions - YouTube
A good amount of that video is a help but the Chevelles steering box and a cougars are 2 different animals.Also,there is 2 different types of front suspensions to be aware of,way different there too.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is online now
This Thread is more than 1358 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
