Best starter for 1970 Chevelle SS 396 - Page 2 - Chevelle Tech
 5Likes
post #16 of 30 (permalink) Old Apr 5th, 16, 12:04 PM
Lang
Re: Best starter for 1970 Chevelle SS 396
Originally Posted by 69SS454 View Post
I'm glad you are happy with your starter but you are wrong. There are millions of gear reduction starters on the road in new cars. They were redesigned because of an inferior design.
You are probably right to some extent. There are a lot of gear reduction starters on the road in "NEW CARS". Why is that, because nothing is built to last anymore. Its a cheaper to produce design, not necessarily better. I'm sure if they were such a vast improvement on such an "Inferior Design", the OP would not have gotten as many responses to either fix/rebuild/replace his original Starter with a like design. Your certainly entitled to your opinion, as are we all. As always..... Just my .02.
langss is offline
post #17 of 30 (permalink) Old Apr 5th, 16, 12:14 PM
I doesn't get any better then the RobbMc with pinion support....
hydro462 is offline
post #18 of 30 (permalink) Old Apr 5th, 16, 12:52 PM
Keith
Using your logic all our old are junk and need replaced becouse no auto manufacturers build new cars like ours using the same style parts.
On a custom build with high compression you might be right. But on a stock built motor or close to stock it's going to be hard to beet a good stock starter.
Tod74 likes this.
Maryland Chevelle Club #682
keithb is offline
post #19 of 30 (permalink) Old Apr 5th, 16, 1:39 PM
I put a JEGS brand mini starter on my 70 Big Block 6 years ago. Spins it over easily, and hasn't let me down. I have no problems with a quality GM style high torque starter, but sometimes with headers they can get heat soaked. Not to mention the physical size should you have to remove it.
70CHEVELLE396 is offline
post #20 of 30 (permalink) Old Apr 8th, 16, 10:43 AM
Lance
For what it is worth, tried 2 different mini-starters on my 1970 El Camino SS with a 454 and Hedman headers. The frost plug boss did not allow you to get the starter more than 1/2 inch or so from the headers, no matter how you clocked the starter. The stock starter has quite a bit more header clearance than the off-shore mini-starter, and possibly less risk of heat soak, but just to be sure I'm going to use a heat shield. I did not try all the ministarters that are available....just passing along my experience FWIW. Remember, the stock starters, although heavy and ugly, were an excellent starter and well worth rebuilding.
vortec710 is offline
post #21 of 30 (permalink) Old Apr 8th, 16, 3:26 PM
Perhaps a moderator will move this to "Electrical".
I've rebuilt more than my share of old-style 10-MT starters. I have a parts cabinet filled with brushes, shift-forks, bushings, leather washers, etc. I suggest the 5-roller starter drives rather than the cheaper 4-roller units supplied in "rebuild kits". Rebuild kits also don't come with the shift forks, and the shift forks are always worn. Either buy another, or weld 'n' grind the fork where it wears on the drive.
Might as well open-up the solenoid, and polish the copper disc and copper contacts, too. Don't break the phenolic cap on the solenoid.
Having said all that, as soon as it warms-up a few degrees, I'm going to drop the 10-MT on my pickup, and install a PG-260 "Delco Mini-Starter". Mine's a rebuilt Delco, not a Communist knock-off. Yes, I'll use the PG-specific knurled starter bolts. Ordinary knurled bolts don't fit the starter housing properly. And if I like the mini-starter, the 'Camino will get one, too.
Schurkey is offline
post #22 of 30 (permalink) Old Apr 8th, 16, 3:38 PM
kevin
fwiw.. my 10.7:1 - 496 motor uses an autozone starter specified for a early 90's chevy pickup with 7.4 L. It is a gear reduction unit, has a lifetime warranty and is small. also use a moroso aluminum heat shield specified for a tilton type starter... absolutely no issues. the shield is slightly modified to work but much better a thermal wrap... this ol' po' boy down here has to make it happen without a lot of fluff....
the heckler is offline
post #23 of 30 (permalink) Old Apr 8th, 16, 9:12 PM
Originally Posted by mr 4 speed View Post
FWIW,my 1970 SS454 LS6 car has no issues with a stock,oem replacement starter.
Me too. Just rebuild your original if it needs it.
BlueSS454 is offline
post #24 of 30 (permalink) Old Apr 8th, 16, 10:51 PM
leo
JMHO, the reason for the PMGR starter is weight reduction and most likely made offshore too. MT-10 for me too.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #25 of 30 (permalink) Old Apr 9th, 16, 12:01 AM
When my MT-10 started acting up when hot replaced it with a GMPP PMGR starter and never looked back. I personally don't like the mini starters with no outer pinion support, and would never use one. Lot easier on the arms installing the PMGR, and tons more clearance to the headers.
72 Chevelle SS conv
72ragtop is offline
post #26 of 30 (permalink) Old Apr 9th, 16, 12:31 AM
Lang
Long long ago in a Galaxy Far Far away a 20 something Kid who just had to have "Headers" on his 396 Chevelle drove to the Super Shops in San Bernardino and bought a set of headers they had on sale. They were on the car in a couple of days and are still there as we speak. That was 1972. No heat shield and stock starter. Never had so much as a hickup. Of course those headers are rusted out and leaky as a sieve, but the point is that starter was on the car from the day the car rolled off the assembly line until the Bendix died and was only off the car for the header install before that. When I finally get to working on the old rust bucket, the headers have to come off to rebuild the control arm bushings, so maybe I will consider a heat shield to add to my 60's technology, but the original style starter will go back on after everything is back in the car. I'm all for "Reliability", and everybody needs to do whatever it takes to make it reliable. Heat Shield or Mini Starter or any combination that keeps you off the side of the road with the hood up. That my friends is the bottom line.
langss is offline
post #27 of 30 (permalink) Old Apr 9th, 16, 11:17 AM
If the O/P is looking to get away from hot re-start type problems and also save some weight Chevy uses this type of gear reduction starter
http://i.ebayimg.com/images/i/260379...-1/s-l1000.jpg
on a lot of their later model cars and trucks.While it doesn't look like a gear reduction piece,if you remove the nose off one of these late models you'll find a planetary set that runs right off the starter's motor.You'll find them on 454's,4.3L V6's,Corvette 5.7L and plenty of other OE jobs.Rebuilt they run about $50-80 and are plentiful in the boneyards too.Lots of people use them and swear by them and they come in the angled bolt pattern so the fit the 168 tooth flywheels found on BB's.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is online now
post #28 of 30 (permalink) Old Apr 9th, 16, 3:45 PM
Schurkey is offline
post #29 of 30 (permalink) Old Apr 9th, 16, 8:39 PM
Todd
If the car is stock go with the original style, if it's a hot rod with high compression buy a high performance starter. On a stock engine a stock starter is fine.
72 Chevelle
70 Nova 540 ,powerglide SOLD
67 El Camino
Tod74 is offline
post #30 of 30 (permalink) Old Apr 10th, 16, 11:42 AM
Originally Posted by Gary S View Post
The original factory 8418 (manual tranny) and 8430 (auto tranny) starters will crank any engine over easily. NEVER get rid of one of those starters or you will regret it.
The stock high torque starters work better and much longer than a gear reduction starter. I've never had any hot start problems with my 8418 starter. It has performed perfectly for 46 years. Why replace it with something inferior?
While I totally agree on the opinion/recommendation of the high torque starter and have 2 of my own that are on my 396 and my SB406.But on the 454+ that I'm building I'll be using the kind of starter I posted a picture of in my last post,mostly for weight savings.
But there is one thing that hasn't been discussed here,perhaps the OP, Margs21X doesn't have a high torque starter.That could possibly be the reason he is having starter problems in the first place.Finding out what he's using right now might help if he posted a picture or posted up the starter's numbers.Just a thought.
71 El Camino SS
This Thread is more than 1548 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
